Tyre Pressure - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jun 18th, 2007, 09:39 PM
minimike7's Avatar
Minitastic
Send a message via MSN to minimike7
Local Time: 05:03 AM
United Kingdom Male View minimike7's Classified Ads
DIY Tyre Pressure
Hi I have the 17" bullets with Pirelli runflats on the front and the standard tyres on the back, 205/45/r17
what do you all do for tyre pressure, as I seem to go through tyres a bit quick and bet its because of tyre pressure,
the little plate on the door says about 35psi front and rear, I never known a car to have the same front and rear, but then the cooper s is very balanced.
What do you all put in yours, ideally people with the 17" alloys?
Old Jun 19th, 2007, 01:51 AM
Bilbo Baggins's Avatar
Local Time: 12:03 AM
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile
The performance of the MINI may be balanced but the car is not. It carries 61% of it's weight on the front wheels and only 39% on the rear. I carry about 4 - 5 psi more pressure on the fronts than the rears to help maintain even tread wear.
To determine this I purchased a tread depth gauge and measure 3 places across the width of the tread, once on each shoulder and once in the middle. If there is less tread in the middle I decrease the pressure a pound or so. If the tread is deeper in the middle then I increase the pressure a pound or so. I try to check every 1,500 - 2,000 miles. As little as 1/64"(.4mm) is detectable with a tread depth gauge.
Mixing brands of tyres on a vehicle can be risky as different manufacturers tires can handle very differently and make your MINI behave in unexpected ways when pushed to extremes.
'06 MCS SB/S R84s(BFG Traction T/A V, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
Old Jun 20th, 2007, 02:07 PM
minimike7's Avatar
Minitastic
I appreciate that, and I never normally would, I am changeing the rear Dunlops for Perelli when they go, sure it wont be long now as i seem to go through tyres petrol and miles like there going out of fashion.
Old Jun 21st, 2007, 06:49 AM
minigolf's Avatar
Blue is the colour!
Local Time: 04:03 PM
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile
In answer to your question ... 38-40psi all round.
And, yes, coventional tyres on one axle, and runflats on the other is a recipe for disaster!
Put the RFs on the back and do a few hand brakies before you buy some new tyres...
Old Jun 21st, 2007, 12:53 PM
minimike7's Avatar
Minitastic
Both Brands are runflats...sorry if that wasnt made clear, i would be that silly
Old Jun 22nd, 2007, 12:03 AM
hyprblu's Avatar
Australia Male
I found that Pirelli tyres did not last as long as Bridgestone or Dunlop...........I currently have Dunlop for street and Bridgestone for track.....
Now REDJCW
What tyre pressure is best? Cooperpot Wheels, Tyres & Brakes 9 Jul 15th, 2006 09:10 AM
Tyre Pressure Help Please Pamster Wheels, Tyres & Brakes 3 Mar 6th, 2006 06:17 PM
Tyre Pressure!!! KMK163 Wheels, Tyres & Brakes 3 Feb 15th, 2006 02:22 PM
What tyre pressure... Fullupo Wheels, Tyres & Brakes 5 Aug 20th, 2003 12:53 PM
Tyre Pressure DocT First Generation MINI Cooper S 0 Jul 17th, 2002 11:36 AM
