| Yes you can use them, just have to reset the system once they are on. The Run Flat indicator works off the ABS sensors and detects the change in tyre circumference through that system. There is nothing on the tyres themselves (unlike Renaault etc where they have something built into the valve). |
| The sensor is part of the ABS system, it actually has nothing to do with the wheels or tyres you chose (well, that's not quite true, but let me explain). The ABS sensors detect the rotation speed of each wheel, if they go out of synch for an extended period (more than just losing a bit of traction or something would do) then the system assumes it's due to a mis-match in tyre pressure and will warn you of a possible flat. OEM, aftermarket, runflat or regular tyres, as long as your wheels are spinning, it will work. |
| Tags: oem |
| Will Aftermarket Wheels Effect The Runflats Sensor (tyre Pressure Sensors) ? ? ? | JCW210BHP | Wheels, Tyres & Brakes | 2 | Sep 15th, 2007 03:55 PM |
| what size tyre can you go 16" oem wheels | sus | Wheels, Tyres & Brakes | 2 | Apr 20th, 2007 09:47 PM |
| Faulty Run Flat Sensor? | fletchie | Wheels, Tyres & Brakes | 2 | Mar 4th, 2006 09:36 AM |
| my flat tire sensor went off for no reason:/ | Burnout | Wheels, Tyres & Brakes | 13 | Dec 3rd, 2004 02:16 PM |
| Run Flat Sensor | Paul Simonds | First Generation MINI Exterior | 16 | Apr 8th, 2002 02:13 PM |
