| URGENT - Wheel Fitting Question (2014hrs 10/07) Please can someone offer some urgent advice (I'm trying to fit wheels on tonight). I have had some aftermarket wheels delivered which appear to have the correct PCD (4 studs with the correct diameter) but the hole in the alloy into which the hub is inserted is larger than the hub if that makes sense? So, think of the hub as the male and the alloy as the female, the female is larger (quite significantly) than the male so the alloy simply moves around. Obviously the alloy could be bolted to the hub but then all the weight and pressure would be on the bolts and not shared by the 'male'. Can anyone advise what has happened and how to explain this to the vendor to get this sorted? Are these for a different car make/model? I really need to get onto them asap so a quick response would be very much appreciated. Thanks! |
| Fantastic, thank you so much for the response! I have purchased Inovit Tarmac 18s in Hyper Silver from www. alloywheels. com. Really impressed with the service thus far, and as soon as I mentioned it today he said he would send some out. However, not great that they weren't sent out automatically given that I told him what car the alloys were to be fitted to. Wheels are here (thought they look a bit rubbish on the photo mock up): http://www.alloywheels.com/product.asp?P_ID=1513&V_ID=27140&strPageHistory=se arch&strKeywords=4x100%20et37,4x100%20et38,4x100%2 0et40,4x100%20et42,4x100%20et45,4x100%20et48,4x100/56-1%20et45&numPageStartPosition=11&strSearchCriteria =any&PT_ID=all&strSort=Low&Make=BMW&Model=New%20Mi ni&strSize=18"&searchSize=18" Itching to get them on now! Thanks again. |
| Tags: hub, pcd, wheel |
| Urgent!!! Steering Wheel Pump Question | KMK163 | First Generation Faults & Fixes | 2 | Apr 13th, 2007 06:10 AM |
| Urgent advice needed on fitting Aero sideskirts | fozworth | First Generation MINI Exterior | 7 | Nov 19th, 2006 07:31 PM |
| 3 spoke wheel airbag, need help, urgent!!! | balint | First Generation Interior & Ice | 2 | Jun 15th, 2006 09:28 AM |
| Hella driving lights currently fitting URGENT help! | oozeymc | First Generation MINI Exterior | 6 | Oct 29th, 2005 03:35 PM |
