| Tags: brake fluid |
| 04 MINI Join Date: Aug 2007 Location: Charlotte, NC USA Local Time: 02:28 AM
Offline | Brakes Hey Folks, Help! The brake sensor tripped at 44,5K miles on my 2004 MINI. It's out of warranty, so the dealer suggested getting quotes from reputable brake shops instead of using MINI dealer service. (One dealership quoted $1,000; the other $1,100 for replacing the front and rear brakes, including pads, rotors and sensors.) So I've got several good quotes in the $675-$750 range, using genuine BMW/MINI parts. But one shop asked me if I need to have the brake fluid flushed and replaced...do I, should I? I'd appreciate any advice...Thanks! Jo Charlotte, NC |
| 05 MCS BEP | You're supposed to have your brake fluid changed every two years regardless of whether or not you need brake pads (it's in the service manual). I just had my MINI's brake fluid changed today. Though probably not really necessary, the reason BMW/MINI prefer you to flush your brake fliud every two years is because if there are impurities in it, the boiling point of the stuff changes and could be a factor in the case of brake fade, particularly after a long hot run. So I would recommend you have your brake fluid changed, especially if you've never changed it since you bought your car. Brake fluid is cheap anyways (less than $20), but the labor part is about an hour. 05MCS BEP - Alta 22mm rear anti-swaybar, Madness CAI |
Offline | I had my last scheduled service (still under warranty) in March of this year. Don't know for sure if the brake fluid was replaced then or not. Will definately do so when I get the brake job done. Thanks again for your help! |
| Brakes | ZR 900 | Faults & Fixes | 5 | Apr 24th, 2007 10:19 PM |
| My brakes are not what they use to be (Help me!) | Chilipeppa03 | Maintenance & MINI Care | 7 | Apr 6th, 2006 12:50 PM |
| Brakes !!!! | GTT 280 | Wheels, Tyres & Brakes | 3 | Sep 7th, 2005 02:32 PM |
| what brakes?! | bryce03 | Wheels, Tyres & Brakes | 21 | Aug 17th, 2005 02:23 PM |
| Help with brakes!!! | neilgj | Wheels, Tyres & Brakes | 1 | Jul 3rd, 2005 11:33 PM |
