| Tags: pads |
| DUNNY | 2yr old, 21k and need new discs needed? Ok so i getting my pads done MCS is nearly 2 years old and they said i need new discs also! surely this would come under the warrenty or "not fit for purpouse" as its only done 21k and this is the first brake pad change and they saying new discs!! Please advise people please! AJ xx DUNNY |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 08:11 AM
Offline | Yup, standard discs and pads wear about the same rate, lots of people just change pads only to find out the discs are below limits well before the new pads are worn , then they have to get new pads again with new discs -No saving there! The Zimmerman discs are a harder steel and you can get 2 sets of pads to 1 disc The Apex discs are cheap and sometimes do not fit ,wear about the same as stock Regardless brake discs and pads unlikely to be a warranty item,much like tyres,wipers,clutch and other wear items |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 08:11 AM
Online | Hi, yes they do wear & they're correct (usually) in suggesting new discs aswell as pads.Check out the GTT Spiroslot discs+pads+fluid kits on our website ..£129+vat front or £119+vat rear.Also there here are some new GTT Big Brake kits coming in this week at a very keen price.....will put up a thread later . Best Regards Roland .GTT ![]() |
| | #6 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 08:11 AM
Offline | The MCS and MC burn discs and pads at a prodigious rate. Consider yourself lucky to get 2 years or 25k out of them. Mine did 15 at tops! :shock: LOL They are wearable part...if disc is just worn and not cracked etc then its wear and tear and not covered. I'd say to BMW that you don't want them to touch it and you will do it...it will still be covered if the parts you buy are BMW. Takes 20-30 mins for dics and pads on the front and a bit longer and special tool on the rear. BMW will charge about 450 for all 4. You can get it elsewhere including better fluid and discs/pads for a lot less! |
| | #7 (permalink) |
| DUNNY | i went kwik fit! life time garentee on pads only got pads dont cause of money but when i get the discs done they'll change the pads for free too ![]() and it was only the fronts backs still ok.... i guess they lasted so long cause i brake using gears as well as brakes! ![]() AJ DUNNY |
| | #8 (permalink) |
Offline | The front brakes wear faster because as you brake the weight moves forward so the front brakes do far more work than the rear. Despite being advised that you need new front discs,you have had only the pads done!!!!! getting new pads fitted at no cost later ,could cost you more than you can imagine Running discs below minimum thickness ,make the car un roadworthy ,and dangerous ,brakes are not an option ,you now have no insurance either Lifetime guarantee.....who's life? |
| | #9 (permalink) |
| Back in a MINI Join Date: Jan 2004 Location: Hampshire Local Time: 08:11 AM
Offline | I can't believe any one would take such a big gamble with safety for the sake of a new set of front brakes and £200. My dealer advised in June that my front brakes were shot (pads shot, discs borderline). I took mine to MiniMania for the Zimmerman Discs and EBC pads! Having seen the parts removed, I got them changed just in time - and these had covered only 18k miles!! Top service though from Adam at MiniMania, and the new brakes are much better than the standard items! ![]() |
| MP3 discs? | harrietb | Interior & Ice | 8 | Feb 7th, 2007 02:52 PM |
| MP3 discs....really?? | jboy_nm | Interior & Ice | 12 | Jan 8th, 2005 05:57 PM |
| Transmission Gone 21K Beware! | Wave | Faults & Fixes | 23 | Nov 14th, 2003 10:49 AM |
| Discs??? | Vesterdux | Engine & Drivetrain Tuning | 2 | Aug 10th, 2002 02:04 PM |
