Performance Torque
Old Oct 3rd, 2007, 03:46 PM   #1
philipnslater
Local Time: 06:47 PM
17 wheels - Offset and Spigot size
Right, first post
Need some help on the girlfriends car. She currently has 17 inch cooper wheels think theyb are called rs8 (8 spokes)
Anyway, what are the offset for mini wheels? also what is the spigot ring size.
Ask me about VW golfs and i know the answers! Mini's someone must know
Old Oct 3rd, 2007, 04:10 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 11:47 AM
Smile Welcome to MINI2 ...
What original equipment wheels and tires are available?
Old Oct 3rd, 2007, 04:39 PM   #3 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Local Time: 07:47 PM
Go to FAQ section. There is a bit just on all the info (with pics) of the MINI wheels and tyres.
MINI offset range between ET45 and ET52 normally. Most are ET45
I believe both R53 and R56 are similar in the offsets they can run.
There are people on here (like me running 17"x7" (standard size) aftermarket wheels on much bigger offsets, even as big as ET30. I run ET45 at the moment but soon to be ET29 due to spacers...I don't know of anyone having issue with scrubbing on 17" ... once you go to 18s you have to be more careful but I ran 18x7.5s with 215 tyres and lowered suspention (-35mm KW) with no scrubbing on ET45 for a while.
Old Oct 3rd, 2007, 04:54 PM   #4 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Quote: Originally Posted by Richard Crofts (original)
I don't know of anyone having issue with scrubbing on 17" ... once you go to 18s you have to be more careful ...
Wheel diameter isn't what counts ... its tire size, wheel width and offset. Given the same wheel width and offset, 215 width tires on 17 inch wheels will be more likely to rub than 215 width tires on 18 inch wheels.
Old Oct 4th, 2007, 09:58 AM   #5 (permalink)
philipnslater
Fantastic help MINIAC
No idea why i couldn't find it using the search facility
Thanks Guys
Old Oct 4th, 2007, 01:15 PM   #6 (permalink)
Richard Crofts
THE STICK
Oh and the MINI hub is 56.1 ... MINI wheels don't need a spiggot ring and each manufacturer of aftermarket wheels uses different sizes so its difficult to say what you need....however a lot seem to use a 73mm hub
OZ wheels and spigot rings Ade1986 Wheels, Tyres & Brakes 3 Sep 24th, 2007 10:33 AM
17x7 RIMS offset 37mm, what tires size will you choose? ongwc Wheels, Tyres & Brakes 4 Sep 12th, 2007 11:50 AM
Wheels and Offset: There are no stupid Qs JohnnyConvoluted Wheels, Tyres & Brakes 14 May 19th, 2006 02:14 AM
HELP - 17 inch Wheels with 38 offset??? CoolJamJar Wheels, Tyres & Brakes 2 Apr 13th, 2006 12:27 PM
Advice before I order (Wheel size and tyre offset) Spoony Wheels, Tyres & Brakes 2 Jul 17th, 2005 09:14 PM
