Tags: , ,
Old Oct 4th, 2007, 12:57 PM   #1
L14MWY
L14MWY's Avatar
Local Time: 01:57 AM
Send a message via MSN to L14MWY
England Lowering on wide wheels
Hi, im considering lowering my mini the only problem is i have 225/35/ZR18s fitted to the car, this has been giving me rubbin if i have 2 passengers in the back for a little while now, if i lowered teh car is there any way to prevent this? or is it a lost cause?
Cheers for any help!
Old Oct 4th, 2007, 12:59 PM   #2 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
Send a message via MSN to Nath316 Send a message via Yahoo to Nath316
well you can lower them but be careful of teh rubbing
one way is too add blocks to the springs so that they do not compress as much whenunder load (ie passengers in back) this does cause a harder ride tho.
you can use the blocks that are used by cars for towing caravans
alternatively dont have passengers
More Air + More Fuel = More Power!!!!!!!!!!!!!!!!!!!
England Male View Nath316's British Racing Green & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Oct 4th, 2007, 01:00 PM   #3 (permalink)
L14MWY
L14MWY's Avatar
you reckon id get any catching when i turn the wheel or anything?
Old Oct 4th, 2007, 01:02 PM   #4 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
at the front mmmm
possibly only way to find is to do it and see
depends on your width I suppose
Old Oct 4th, 2007, 01:03 PM   #5 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Not on the rear, obviously but 225 is quite wide. Whats the actual rim width? This does make a difference as a 8" rim running a 225 will sit fatter than a 7.5 rim with a 225.
Old Oct 4th, 2007, 01:08 PM   #6 (permalink)
L14MWY
L14MWY's Avatar
18 inch wheels 7.5 i think
Old Oct 4th, 2007, 01:11 PM   #7 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
not to sure on the clearance on Minis so cannot comment to be honest I will bow out to the more experienced
Old Oct 4th, 2007, 01:17 PM   #8 (permalink)
L14MWY
L14MWY's Avatar
ok no problem
Old Oct 4th, 2007, 01:18 PM   #9 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
however i would say that as you on 7.5 you should be ok
Old Oct 4th, 2007, 01:19 PM   #10 (permalink)
L14MWY
L14MWY's Avatar
lol... ok, how much are these blocks to go on the back?
Old Oct 4th, 2007, 01:36 PM   #11 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
not sure
they are not expensive
on here with diagrams
http://www.caravanclub.co.uk/nr/rdon...ensionaids.pdf
detail
Only for cars with coil springs:
• Aeon Coil Lift £31 - £35
• Do'nut £30 - £35
• Grayston £19 - £35
A friend of mine had some fitted on his modified car as he had alot of weight over the back end and it avoided rub
Old Oct 4th, 2007, 01:39 PM   #12 (permalink)
Fu Manchu
Formerly HUMPH
Send a message via MSN to Fu Manchu
L14MWY. You need to tell us the following so we can have a proper stab at it.
-Width of the wheel
-offset
the make and model of the wheel may help us get this info if you don't know.
I'm on 18x7.5 with an offset of 45 and run 215/35/18, and have never had rubbing. Don't carry rear seat passengers really though.
If you give us the info above there will be someone on here that can help I'm sure.
Wales Male View Fu Manchu's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 4th, 2007, 01:42 PM   #13 (permalink)
L14MWY
L14MWY's Avatar
the wheels are Masitaly Sagitta 18"'s
225/35/ZR18
7.5 width
and i THINK the offset is 45?
Old Oct 4th, 2007, 01:52 PM   #14 (permalink)
Fu Manchu
Formerly HUMPH
If the offset is 45 then your wheels are the same size as mine. You might be better off with the 215/35/18 tyres then. I'm on Eibach springs and have never had any rubbing in normal driving, but like I say I don't carry rear passengers. Can't find info on the wheels as they appear to have gone out of business.
Old Oct 4th, 2007, 02:01 PM   #15 (permalink)
L14MWY
L14MWY's Avatar
whats the difference between 225/35/18 and 215/35/18 like? would 215s fit my car?
Old Oct 4th, 2007, 02:16 PM   #16 (permalink)
golo
golo's Avatar
Local Time: 01:57 PM
i tried 225/35/18 when i bought the wheels (18 x 8 + 42), and it rubs all the time
and i'm using 215/35 on my 18 x 8 +42 wheels, and no problem at all
2004 MV agusta SPR 097/300
2006 mini cooper S JCW 210bhp
New Zealand   Reply With Quote
Old Oct 4th, 2007, 02:17 PM   #17 (permalink)
L14MWY
L14MWY's Avatar
whats teh difference with 225 and 215 like
Old Oct 4th, 2007, 02:17 PM   #18 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
the difference i believe is teh overall tyre width so as they are narrower they do not rub
Old Oct 4th, 2007, 02:31 PM   #19 (permalink)
Fu Manchu
Formerly HUMPH
Quite 215s are 10mm narrower than 225.
The 35 figure is the profile of the tyre as a percentage of the width. So
225/35/18 = 615 mm diameter
215/35/18 = 608mm. Slightly smaller
MINI's stock 17"s are 616mm, 205/45/17
So basically 215's are smaller and give approx 4-5mm extra clearance all round. Don't forget this means there is 4mm less of rubber between the rim and the road.
Useful link.
TYRESAVE: Tyre Size Calculator
Old Oct 5th, 2007, 08:10 AM   #20 (permalink)
steve11
Mad Modder
steve11's Avatar
Local Time: 10:57 AM
I believe your problem is the 225 tyre width.
A 215/40/18 tyre would be the ideal size for a 18" rim as this equates to a 2% overall increase in height & if your rims are a 45 offset you wont experience any rubbing.
By the way i am running 19x8 rims with 215/35/19 tyres & lowered Eibach springs.
Keep in mind it is tyre width & rim offset that causes the rubbing on the plastic inner guard liner, NOT the tyre height, so there is no need to decrease the overall height, not to mention the poor asthetics of a small wheel/tyre combo.
Australia Male View steve11's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
supa wide wheels on MCS... kevinyu21 Exterior 2 Jun 17th, 2007 08:33 AM
wide wheels pablo81 Wheels, Tyres & Brakes 6 Jan 14th, 2006 01:00 PM
wide wheels no mod thebulletz Wheels, Tyres & Brakes 2 Aug 5th, 2005 07:24 PM
Help Needed - What Wide Wheels are out there? monkeynuts Wheels, Tyres & Brakes 9 Nov 30th, 2004 06:41 PM
