Removing runflats - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Nov 9th, 2007, 10:23 AM
Local Time: 04:06 AM
Northern Ireland Male View hoojkel's Classified Ads
Removing runflats
Don't know if this has been asked before but if runflats are taken off wheels, can the same tyres be put back without any ill effect, ie, can the shape be affected when taking off and put back on and should they be put back on. Thinking of getting wheels re-sprayed but i'm concerned whether the runflats shape will be affected if they are taken off then on again and don't want to fork out for any new tyres.
Old Nov 9th, 2007, 10:28 AM
minicabrio's Avatar
Soon to be deleted !!
Local Time: 03:06 AM
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Due to the extra force required to remove the runflats from the rims, it not uncommon for fitters to damage tyre walls when removing them - normally this isn't an issue as tyres are usually discarded when changed. I've seen this happen on quite a few tyres.
Providing the are removed carefully, with no damage to the sidewalls, they could be re-fitted.
Old Nov 9th, 2007, 10:39 AM
yeah, been concerned that if someone messes up when removing them then I would have to end up paying for new tyres when the old ones were perfectly good. They would surely be obliged to pay for them if they did damage them?? Shouldn't they??
Old Nov 9th, 2007, 11:11 AM
minicabrio's Avatar
Definitely ask the question before they begin.
You'll probably find otherwise there is some disclaimer in their small print which says "We are not responsible........"
Is it OK to run non-runflats front and runflats back? Darren S Wheels, Tyres & Brakes 14 Feb 17th, 2009 08:51 AM
Weights : 4 runflats vs. 4 + 1 non-runflats. damiond Wheels, Tyres & Brakes 0 May 10th, 2006 05:13 AM
non-runflats & runflats martyn*w Wheels, Tyres & Brakes 4 Mar 14th, 2006 07:23 PM
Runflats Vs non Runflats ride quality WORKSRACER Wheels, Tyres & Brakes 11 Jan 18th, 2006 05:18 PM
I replaced my 17" runflats on S-spokes with 16" non-runflats on X-Lites beej Wheels, Tyres & Brakes 2 May 25th, 2005 05:05 PM
