Mighty Stripes
Tags: ,
Old Nov 18th, 2007, 10:21 PM   #1
Dave_Boost777
Local Time: 10:49 AM
Runflats
Had my first 10,000 miles service yesterday and was told my two front tyres need replacing. I asked if i could have normal tyres and the guy told me it wasnt possible because the rim is designed for runflats and they are £200 each or something. I was also quoted £40 odd for wiper blades :S
Anyway, its not the cost that gets me, i just find the runflats pretty crap. Can i get normal tyres for my 17" S lights? Will mini do them at all or will i have to go elsewhere?
Old Nov 19th, 2007, 04:54 PM   #2 (permalink)
crumy
Ancient & Loyal
Local Time: 09:49 AM
Yes u defo can, there talking bu!!$hit & trying to rip u off. I'm nearing the end of my 2nd set & searching myself. It was only after purchasing those that I searched the subject & then the garage I've used regular & I got my last set from recommended this time i consider changing to non-RF. I've never driven my mini without RF but can imagine it'll improve the ride & handling no end, so un-even country roads with divots & pot holes will be a pleasure to drive down!!
I've also found that I need to re-track my car far too often & I’m getting uneven inside tyre wear(both I’ve read about on forums), which i'm sure is a combination of the solid tyre walls not able to give any - which is made worse being low profile & having 2 drive around 30 r-a-b a day going 2 & from work (plus my tendencies to drive without caution)!
You may want to find a decent tyre garage(non BMW) that can offer VFM & advice as your going to be mixing non-RF with RF until they need replacing. If you do go for the non-RF option you just need to carry a tin of tyre weld or a space-saver wheel (there is a space under the car for it) should the unthinkable happen. And don’t forget the RF indicator will still work, so if you’ve a slow puncture where one of the lucky ones who’ll have a big bright indicator on the dash saying so!!
Use the power of the internet for a decent valued pair such as tyretraders.com & valuetyres.co.uk!
Old Nov 19th, 2007, 07:58 PM   #3 (permalink)
slim_boy_fat
I'm running GY Eagle F1 GSD3's 215/45-17.
Makes a massive difference.
Old Nov 19th, 2007, 08:31 PM   #4 (permalink)
MINImeat
MINImeat's Avatar
Local Time: 04:49 AM
At the risk of boring all longtime MINI2ers, I'll just repeat that there is nothing special about the wheels used on the MINI with runflat tyres.
By now, many many MINI owners have installed non-runflats on their original wheels.
The decision is yours to make based on your priorities.
Runflats do allow you to continue driving with a puncture.
MINImeat
B/W MCS
United States View MINImeat's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 19th, 2007, 09:39 PM   #5 (permalink)
Dave_Boost777
Ive decided ill definately change them then, but what about the rear tyres? Should i leave them RF or swap them too?
Is anyone doing this? is there any problems with doing this?
Old Nov 19th, 2007, 09:52 PM   #6 (permalink)
humph
Back To My Old Self
Send a message via MSN to humph
Mixing run flats and ordinary tyres is generally advised not . Mixing any different types of tyres is not a good idea as different brands will have different handling characteristics/limits.
Wales Male View humph's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Nov 20th, 2007, 01:49 PM   #7 (permalink)
r1_kde
JCW 210 "apparently"
r1_kde's Avatar
I am in the same situation! I am based in Solihull and so far no one I have gone to will change to non RF on my s lights...
Does anyone know who will? after having the rims powdercoated I do not want to change to aftermarket, oh and I like them.
Is it OK to run non-runflats front and runflats back? Darren S Wheels, Tyres & Brakes 13 Feb 10th, 2008 06:22 PM
Did you replace with Runflats or Non-runflats? David_MCS Wheels, Tyres & Brakes 36 Aug 15th, 2007 06:35 PM
non-runflats & runflats martyn*w Wheels, Tyres & Brakes 4 Mar 14th, 2006 07:23 PM
Runflats Vs non Runflats ride quality WORKSRACER Wheels, Tyres & Brakes 11 Jan 18th, 2006 05:18 PM
I replaced my 17" runflats on S-spokes with 16" non-runflats on X-Lites beej Wheels, Tyres & Brakes 2 May 25th, 2005 05:05 PM
