Best 205/45R17 OR 215/40R17 Tyres and wheels??? (non r/flats) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Dec 3rd, 2007, 09:28 PM
aml's Avatar
aml
Local Time: 04:06 AM
United Kingdom View aml's Indi Blue & Body Color 1st Gen MINI One Profile View aml's Classified Ads
Hi,
i am buying some genuine R90 wheels for my mini one and am having a look at tyres, what do people think are the best non run flats for best grip, wet & dry, wear etc?
also, what do people think are the best 17'' oem mini wheels (including JCW wheels) my opinion is the R90s... does anybody have a list of the oem wheels and their weights??
cheers
Old Dec 4th, 2007, 11:51 AM
Local Time: 05:06 AM
Italy
Well, i don't know if they are the best but i'm pretty satisfied with my Bridgestone Potenza RE050A...
Old Dec 4th, 2007, 03:19 PM
MINIAC's Avatar
Canned
Local Time: 08:06 PM
See what tires others are running ...
Tire Statistics
Old Dec 4th, 2007, 03:41 PM
aml's Avatar
aml
this may contradict the title a bit now, so i may change it, but i am now considering 215/40R17 tyres also, as the overall diameter change is -5mm instead of +7mm with 205/45R17 (changing from 175/65R15)
Old Dec 4th, 2007, 06:25 PM
Wind Diesel's Avatar
Living in my MINI dream !
Denmark Male View Wind Diesel's Lightning Blue & White 2nd Gen MINI Cooper Diesel Profile
My plan was to go for 195/40-17" on a 7,5" wheel - but Toyo don't make that size, so i will be using 205/40-17" instead.
Heggelund&Wind Photographix-Mini Dooper R56 LiB/W - My MINI Blog
Old Dec 4th, 2007, 08:19 PM
Tigger, Eeyore & Roo's Avatar
Focus RS & Land Rover FL2
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile View Tigger, Eeyore & Roo's Classified Ads
I changed the wheels and tyres on my old R50 Cooper from 15" with 175/65R15's to 17" S Spokes with 205/45R17 Avon ZZ3's. After about 700 miles I swapped them back again and sold the 17" wheels.
I loved the look of the 17" wheels and it did turn in faster, but the car was quite a bit slower, harder riding, thirstier and it tramlined badly. The wheels were also too heavy for the dampers to work properly.
Although there was extra grip with the 17" wheels, It was difficult to exploit it with the power available.
I'd recommend trying a Cooper with 17" wheels before commiting.
Tigger.
May '04 - Feb '07 R50, Feb '07 - May '10 R53. Enjoyed our time with MINI's, but ran out of space! Now Focus RS & Land Rover powered...
Old Dec 5th, 2007, 02:20 PM
Italy
, can you imagine how slow is my One (engine stock, for now...) with 17"? Still, I love how they improve handling so I'm not going back to smaller rims.
Old Dec 5th, 2007, 02:59 PM
humph's Avatar
IJ 2009 - Team 81
Local Time: 03:06 AM
England Male View humph's Dark Silver & Silver 2nd Gen MINI Cooper S Clubman Profile
Tigger.
The S Spokes are the heaviest wheel 17" MINI produce. The problems Tigger lists above are quite common. I had S spokes on my first Cooper ,and to say the car was sluggish with a tram lining problem was an understatment. I would never recommend anyone fit heavy rims to their ONE/Cooper as they seriously effect the cars acceleration/handling. The R90s you mention fitting are the second heaviest 17" rim MINI do, and if they are replicas may be heavier still. Light weight wheels are the way forward if you don't want the problems mentioned. That said there are a lot of members running R90's and S spokes quite happily.
Sorry that went off topic a tad. I run Toyo proxes (18") and am very happy with the way they perform in all weather. They seem to last quite well too, about 32k on the last set of fronts.
Old Dec 5th, 2007, 03:41 PM
batou's Avatar
Turbo Schmurbo...
United Kingdom Male View batou's Dark Silver & Black 1st Gen MINI Cooper S Profile View batou's Classified Ads
I recently had 215/40 R17 Goodyear Eagle F1 GSD3 fitted to the Cooper S (on S Spokes) and I'd go as far as to say they perform almost as good in the wet as the previous run flat Dunlop SP9000's / Pirelli Eufori@ did in the dry. Unbelievable grip in the wet especially with 200 brake going through them!
When talking fails, it's time for violence. ~ batou.
Old Jan 10th, 2008, 09:05 PM
mab01uk's Avatar
Just fitted 215/40 R17 Goodyear Eagle F1 GSD3's........like many others on here have said I am amazed at the improved grip and smooth quiet ride when compared with my old Pirelli Eurfori runflat tyres. As its not an S I have also fitted a 115 /70 x 15" Mini space saver spare tyre under the boot floor just in case.
Tags: , ,
Run Flats or Normal Tyres mckeg4 Wheels, Tyres & Brakes 20 Nov 28th, 2008 02:58 PM
change run flats to normal tyres dee Wheels, Tyres & Brakes 4 Jun 5th, 2008 09:13 AM
Is there a noticable ride difference between run flats and standard tyres? dazotron Wheels, Tyres & Brakes 7 Jan 1st, 2007 01:52 PM
