| Tags: tyres |
| | #21 |
| MINI2 Regular Join Date: Feb 2008 Location: London Local Time: 03:16 PM
Offline | Bob, I'm thinking of ditching the runflats and getting standard tyres fitted, as I too am getting weary of the noise and throw from bumps and potholes in our tremendously well kept British roads . I would like the reassurance of at least having a repair kit (a space-saver spare wheel would be better, but I don't think the well in the boot is deep enough). How big is the Mobility Kit? Can it be stored under the flap in the boot?Cheers. |
| | #22 (permalink) |
| MINI2 Regular | I'm quite surprised at this. What size wheels do you have ? I have T1 R's on my 17's on my R50 Cooper, having replaced the runflats for them. They're cheaper than runflats, and I find the grip brilliant. You can feel the tyre walls loading up much easier so they are less likely to suddenly snap and put you in a field. I've also now put a Cusco Front Strut Brace on and I couldn't ask for any more front end grip ! ![]() |
| | #23 (permalink) |
| Mini Design Philosopher Join Date: May 2004 Location: Berkshire, UK Local Time: 03:16 PM
Offline | The 15" wheels don't come fitted with runflats, only the 16" and 17" wheel options - at least in the UK market anyway. A dealer once told me that if I replaced my runflats with normal tyres it could cause errors with the ABS sensors if the tyres go flat, causing the ECU to malfunction - and that wouldn't be covered under warranty! However I would let your insurance company know, because they can void your insurance if anything is incorrect. |
| | #24 (permalink) |
| MINI2 Newbie | Absolute ********. CYA time from the dealer I'm afraid. Realistically, if you have a puncture of any kind then you shouldn't be driving the car in a fashion likely to trigger the ABS and quite how that impinges on the ECU negatively I can hardly fathom. Simply put, if the RFTs are replaced by standard tyres then the unsprung mass is reduced leading to better handling, less bumpsteer and in all likelihood improved tyre wear. If RFTs are the be all and end all, why does the M Division not fit them on their vehicles? My Z4M is the only Z4 model not fitted with them so that had to tell you something. They're rubbish. End of. |
| | #25 (permalink) |
Offline | I have just had my RFTs replaced with conventionals, and I must say grip and comfort has improved. Of course, the major plus-point for the RFTs is that in the event of a blow-out at high speed, you are (reportedly) less likely to lose control of the car. With my conventionals I must now accept that I drive at increased risk! |
| | #26 (permalink) |
| FOM Test Pilot Join Date: Mar 2008 Location: Sunny South Coast! Local Time: 03:16 PM
Offline | I will always maintain that fitting non-run flat tyres to my 04 MCS was the single best mod £ for £ that I have done to date. If you can afford to I would say, like many others, that the Goodyear eagle F1 GDS3'S are the best pick for a good all round tyre, and Toyo T1R seem to be a popular choice, although I think they aren't nearly as good wear wise or in the wet as the Goodyear. When it comes down to runflats I found that the Pirelli Euphoria's were by far the worst run flats and when I had the Dunlop SP sports I enjoyed those much better! Anybody changing them just remember to buy some tyre weld from Halfords in case you get stuck in the middle of nowhere with a flat tyre... it is also worth remembering that most Kwick Fit type places will not go near your MINI because apparently its some kind of saftey requirement that all cars with RF indicator must have RF tyres. |
| | #27 (permalink) |
Offline | Thanks Feenaldo, I am awaiting delivery of a Mini Mobility kit to go in the boot. KwikFit Whetstone were happy to fit conventionals to mine, as long as it was noted that it was by customer request. |
| | #28 (permalink) |
| MINI2 Regular Join Date: Nov 2006 Local Time: 03:16 PM
Offline | I found kwikfit a nightmare. they repaired a flat runflat once for me but then wouldn't do it another time claiming they are not allowed to repair runflats (and i had not driven on it very flat 20 psi minimum for a couple of miles). They have also said they are not allowed to put non runflats on minis. even though the 15 inch wheels come with them!! They said some dodgy back street garage might do it. I think what they meant was that an honest independant garage offering resonable prices and good customer service might do it! ![]() Kwikfit are arrogant idiots (and their staff are some of the stupidest people i have ever met!) ![]() |
| | #29 (permalink) |
Offline | I agree that Kwick Fit is a little like the as forest Gump would say, " a box of chocolates, you never know what you're gonna get!" So some are good and some are like the coffee creams i.e waste of space! Because Run Flats have such a tough sidewall on them, they are not easy to fit, certainly not as easy as a standard tyre, thus sometimes they avoid it knowing it will be a pain to change purley to avoid any hassle. If Kwick Fit refuse to do anything with your tyres, take it as a compliment because what they are actually doing is saying that you look too intelligent to rip off so they are going to send you elsewhere ![]() I hope you all get on well with your tyre changes, let me know what you got and what you thought of it! Enjoy your new handling but be extra careful for the first 100 miles or so because they need to scrub in and may take you by suprise as you hurtle round your favorite back roads ![]() Last edited by feenaldo : Mar 8th, 2008 at 03:44 PM. Reason: Spelling Errors :D |
| | #30 (permalink) |
| MINI2 Senior Join Date: Nov 2006 Location: London Local Time: 03:16 PM
Offline | If you have a Cooper or One you can fit a space-saver spare wheel..........but not the MCS due to exhaust and battery box. Link here to all he parts needed to fit a spare wheel under the boot floor. I fitted a spare to my MINI last month when I changed to normal Goodyesr 215 /40 x 17 F1 tyres :- http://www.mini2.com/forum/wheels-ty...t-numbers.html |
| | #33 (permalink) |
| MINI2 Regular Join Date: Sep 2007 Local Time: 03:16 PM
Offline | I had runflats on mine when I first got it (Sept 07), and had a blow out on the way to GTT (150 mile drive). It was quite amazing how far I could get before pulling over 10 miles +. The inside wall of the tyre had totally disintigrated. However I changed the fronts that day to Falkens, as they were cheap and even though they are not a premium tyre, the handling and ride was noticibly better. How moving to Toyos all round |
| | #34 (permalink) |
| MINI2 Newbie Join Date: Mar 2008 Local Time: 02:16 PM
Offline | I'm new to this forum and was reading with interest the comments on Runflats V's Non runflats. I am the proud owner of 2 Minis, a New 57 plate Auto with 17" Cooper S Works alloys with Non Run Flats and a 56 plate Manual with the R90 Cross Spokes which I changed to Non Run Flats a few days ago and to date I'm trying to come up with a reason why anyone would stick to Runflats. If you're thinking of changing - Do It....... Sorry about refering to the Minis by age, I'm not sure of the manufacturer codes ! |
| | #36 (permalink) |
| 3 JWL Join Date: Nov 2006 Location: Salisbury Local Time: 03:16 PM
Offline | Being essentially lazy and with most of my motoring motorway cruising, I've stuck with RoF tyres, despite the general voting for 'normal' rubber. My experience is that the Pirelli is dreadful, with tramlining at around 50% wear, the Dunlop is OK but I've now just put on my 3rd pair of Goodyears and they are more compliant and predictable than either. It also helps that their price seems to have dropped - that pair last week were £203.61 including all the 'extras' that get added in. |
| | #37 (permalink) |
| MINI2 Newbie | runflat ? r50 cooper,front tyres need replacing costing £200. priced out toyo p1rs, £288 for 4 with blackcircles & local garage to fit. before purchasing phoned the garage & they said no way would they change runflats to non runflats, a rim issue & unsafe. feeling a bit stuck here, is it OK to put these tyres on my mini 5 spoke alloys or is there an issue. anybody feel free |
| | #38 (permalink) |
| MINI2 Senior | I changed my front two runflats to Hankook Ventus S1 Evo's (£220 all in), due to wear on the factory fits. Seem a little better - the ride isn't AS harsh, but still a bit harsh (MCS with SS+ though) as expected. Hankook Ventus S1 EVO K107 Tires - Tire Size & Price Details - 1010tires.com I was thinking of non-runflats at the time, but didn't want to replace all 4 tyres - money and all that. ![]() |
| | #39 (permalink) |
| MINI2 Master Join Date: Apr 2005 Location: Watford, Herts. UK Local Time: 03:16 PM
Offline | There are lots of people on here running non runflats on MINI rims, with no issues at all. Just find a tyre fitter that will is all. |
| | #40 (permalink) |
| MINI2 Regular Join Date: Oct 2007 Location: Glasgow Local Time: 03:16 PM
Offline | Oh i had beet be careful with the wording just incase i upset a sensitive soul!!! I would suggest the garage who are not fitting the tyres must be called Richard Head, they talk with forked tongue and actually dont know what they are talking about. I would suggest you don’t even ask them to put air in your tyres let alone fit a new set. Is that ok for everyone, post acceptable????????????????? Can i use the words merchant banker too. ![]() |
| Is it OK to run non-runflats front and runflats back? | Darren S | Wheels, Tyres & Brakes | 13 | Feb 10th, 2008 06:22 PM |
| Did you replace with Runflats or Non-runflats? | David_MCS | Wheels, Tyres & Brakes | 36 | Aug 15th, 2007 06:35 PM |
| Weights : 4 runflats vs. 4 + 1 non-runflats. | damiond | Wheels, Tyres & Brakes | 0 | May 10th, 2006 05:13 AM |
| Runflats Vs non Runflats ride quality | WORKSRACER | Wheels, Tyres & Brakes | 11 | Jan 18th, 2006 05:18 PM |
| I replaced my 17" runflats on S-spokes with 16" non-runflats on X-Lites | beej | Wheels, Tyres & Brakes | 2 | May 25th, 2005 05:05 PM |
