Brake Pads - Handbrake Hi, Changed the rear pads on my msc today. Took about hour and half in p****n rain! went ok, used special tool from ebay, reset brake light too. Now the handbrake seems to pull up a good bit more than before? is this normal? have i done something wrong? or do i just need to adjust the handbrake?any advice welcome! the brakes seem to be working fine, pedal feels ok, little soft maybe? ![]() thanks! |
| My handbrake didn't need any adjustment after changing front and rear pads, so I left it be. The Bentley manual doesn't say anything about adjusting the handbrake in their section on replacing rear brake pads. There is a specific method of adjusting the handbrake when it needs to be adjusted which does involve loosening the adjusting bolt until slack, taking the pads out, compressing the caliper, reinstalling the pads, and adjusting the bolt near the handbrake, until the spring at the rear caliper is in the right position, etc. ![]() |
| If worn pads are replaced with new pads, the rear pistons need to be pressed in. To adjust the hand brake, pull the p-brake boot up and adjust via the nut. If the hand brake needs adjustment after a period of time, adjust via the nut; it is not necessary to press the pistons in again. A mid ground between brake drag and how far the p-brake is pulled up has to be found. |
| Tags: brakes, handbrake, pads, rear |
| Which AFTERMARKET brake pads will be compatible with brake sensors? | wrxtomini | Maintenance & MINI Care | 0 | Apr 22nd, 2006 03:17 PM |
| Brake pads and brake disks (rotors).. HELP | GIII | First Generation MINI Cooper S | 2 | Nov 10th, 2003 07:23 PM |
| new alloy and tyres will i need to get new brake discs and brake pads | TREBALZ | Wheels, Tyres & Brakes | 7 | Sep 23rd, 2003 11:24 PM |
| Brake pads | Yui | Maintenance & MINI Care | 0 | Jan 17th, 2003 06:23 PM |
| Brake Pads | Wayne | General Discussion | 4 | May 9th, 2002 11:11 AM |
