Advice on BBS wheels please?? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Dec 14th, 2007, 01:48 AM
harperboy's Avatar
Local Time: 09:36 AM
England Male View harperboy's Classified Ads
I have been offered 4 BBS RX 17" wheels with next to new tyres on them in mint condition .
I think they are very nice wheels n would look good on the mini but have a few concerns. I think the price that i have been offered them at seems very good but i'm not too sure.
My questions are: What do you think they are worth paying for?
Also, does anyone no if they would fit onto a 52 plate mini one??
I dont have much more details on them other than they are 4 stud, 7" wide. Could there be different distances between four stud wheels such as the studs are spaced at different distances apart? Also what about rubbing on arches??
One additonal point what about the fitting if i decide to go ahead with the eibach lowering springs (30mm) I know there is several issue's here but any advise would be greatly appreicated!
Thanks in advise, Sam.
Old Dec 14th, 2007, 02:27 AM
MINIAC's Avatar
Canned
Local Time: 01:36 AM
You need to find out the bolt pattern, centerbore and offset of the wheels.
Old Dec 14th, 2007, 05:11 PM
harperboy's Avatar
If i can find that out will people know if that will fit to the mini??
Old Dec 14th, 2007, 05:14 PM
MINIAC's Avatar
Canned
They'll be able to give you an informed opinion
Old Dec 14th, 2007, 05:15 PM
harperboy's Avatar
Lol, cheers, i'll see what i can find. Is it just me or is all this wheel business quite complicated!
Old Dec 14th, 2007, 05:19 PM
MINIAC's Avatar
Canned
I'd recommend spending some time reading the following:
Wheels and Tyres FAQ
Old Dec 14th, 2007, 05:49 PM
harperboy's Avatar
That has been quite helpful, cheers mate, i found this:
'''What are the bolt pattern, centerbore and offsets for wheels?
The bolt pattern is 4x100mm.
The centerbore is 56.1mm.
The offset (ET) can range from 35mm to 52mm depending on the wheel size, as detailed in the FAQs on factory and aftermarket wheel availability.'''
I take it the bolt pattern figure refers to the number of holes for bolts to go into and the diameter of them therefore the wheels i get need to be the same bolt pattern as that above??
Is the centrebore the round metal bit in the middle of the hub then? Should the wheels give a measurement in regards to this??
I have found out the offset is ET42 and the wheels i have on at the minute are ET45 so i dont think that would cause to many problems
Old Dec 14th, 2007, 06:16 PM
They will fit im running bbs RCs 17x7 et42 the center bore of the wheel is bigger but they have things called spiggot rings which reduce the size to 56.1 for the mini.
Last time I saw a set like your talking of they were around 700 used with decent brand tyres!
Old Dec 14th, 2007, 06:21 PM
harperboy's Avatar
Cheers for the info dave. My only concern is that on the BBS website when searching for the wheels for the mini it says RX214 or or RX215. Im assuming the refers to all the different types of BBS RX wheels for different models they do. The ones i have been offered are RX217 so im slightly worried the bolt pattern might be slightly different or something. What actually is the mm measurment of the bolt battern refering to?
Also where do you get spiggot rings??
Thanks dave.
Old Dec 14th, 2007, 06:46 PM
MINIAC's Avatar
Canned
The highlighted text in the FAQ are clickable links:
A bolt circle of 4x100 would indicate a 4 lug pattern on a circle with a diameter of 100mm.
I suggest contacting BBS for specifications on RX217.
Tags: , , , ,
Advice on choosing wheels please!! kimoss Wheels, Tyres & Brakes 44 Jun 13th, 2006 02:30 PM
Getting Winter Wheels - Need Offset Change advice Voodoo Wheels, Tyres & Brakes 4 Oct 22nd, 2005 01:47 PM
18x8 wheels - advice needed Roofas Wheels, Tyres & Brakes 4 Jul 22nd, 2005 02:05 PM
Advice re changed wheels/handling MINI 59/04 Wheels, Tyres & Brakes 9 Aug 4th, 2004 11:14 PM
17 wheels zenons dsc and cycle racks - advice please redditchmini First Generation MINI Cooper S 6 Dec 4th, 2002 08:44 PM
