GizzmoUSA
Tags: ,
Old Jan 7th, 2008, 04:52 PM   #1
aml
aml's Avatar
Local Time: 08:31 PM
anybody using 16inch TD pro race 1.2 ??
hi,
i am buying new wheels for my car and am wandering what 16inch TD pro race 1.2s look like, could people please post pics and if the car is lowered, offset etc please
help much appreciated
United Kingdom View aml's Indi Blue & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jan 7th, 2008, 05:08 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 12:31 PM
Online
16x7 Team Dynamics Pro Race 1.2 wheels are available in 35, 40 and 45mm offsets.
ET45 would be best for a lowered MINI.
Old Jan 7th, 2008, 05:18 PM   #3 (permalink)
aml
aml's Avatar
thanks, would et45 be ok for standard height mini also, as i may lower it in the future, is et45 wider than et35, or the other way around? thanks
Old Jan 7th, 2008, 05:35 PM   #4 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
The lower the offset the more the wheels are pushed out. As you go from ET45 to ET35, the closer the outside of your tires come to the wheel well trim. ET45 is the lowest offset on OEM wheels and is the best choice if you want to lower your MINI later.
Old Jan 7th, 2008, 05:43 PM   #5 (permalink)
Goonery
Time for CHANGE !
Something like this I'd imagine
http://gallery.mac.com/goonery/10001...&type=me dium
These are 17"s BTW, but you get the idea
Old Jan 7th, 2008, 05:43 PM   #6 (permalink)
aml
aml's Avatar
ok, what is the best offset for 17inch of same wheels? i only put 16inch in the title because i have pictures of mini's with 17inch 1.2s on, i may be lowering the car, but will be 30mm or less, probably over a year away, thanks
Old Jan 7th, 2008, 06:52 PM   #7 (permalink)
aml
aml's Avatar
thanks for peoples help, think i will be having 17inch as i won't be able to lower the car for a while and 16inch will look too small
Old Jan 7th, 2008, 07:38 PM   #8 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
The same ... ET45 .
Old Jan 8th, 2008, 10:45 AM   #9 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
I run the Et45 on -35mm KW springs with 215/45 tyres (used to run 205/45 and 215/40s as well) None rub except the 215/45s (adn then only a little under full load with the rear loaded with stuff or people. Fronts never rub. Mine could do with a bigger -40 or 38 et on the front at least maybe even a bit out on the rear to make it look and handle better.
will 215/40-16 fit my 16inch X-lite? asinn Wheels, Tyres & Brakes 7 May 3rd, 2006 11:23 PM
16inch runflats versus 17inch nonrunflats cct1 Wheels, Tyres & Brakes 4 Sep 2nd, 2005 09:36 AM
16inch 5 star alloys with Tyres ollie20016 For Sale 2 Apr 17th, 2004 09:55 PM
Experiences pls on 16inch run-flats CHETCOOPER Wheels, Tyres & Brakes 2 Sep 18th, 2003 10:22 PM
DS/W with white 16inch Jolly Jumper MINI Cooper S 3 Oct 4th, 2002 12:00 PM
