Visit Mini Mania UK
Tags: , ,
Old Jan 7th, 2008, 06:56 PM   #1
aml
aml's Avatar
Local Time: 08:10 AM
ET 38 17x7 205/40R17 rubbing?
hi,
i am looking for TD pro race 1.2s for my standard height mini one and can have them in ET45 or ET38, ET45 should be fine and not rub, but does anybody know if ET38 would rub? i do carry passengers in the back occasionally.
205 40 r 17 tyres 17x7 wheel
thanks
United Kingdom View aml's Indi Blue & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jan 7th, 2008, 07:43 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 12:10 AM
The problem with ET38 is if you lower your MINI and ever want to run 215 width tires you might having rubbing.
Old Jan 7th, 2008, 09:04 PM   #3 (permalink)
RyanK
Pure Silver Batman
RyanK's Avatar
Send a message via MSN to RyanK
Hi
Im running 17" ET38mm Team Dynamics 1.2's with 205/45 tires.
Yes they do rub when theres passengers in the back, and im running standard height
<a href=http://farm3.static.flickr.com/2084/2452238513_53d1113248_o.jpg target=_blank>http://farm3.static.flickr.com/2084/...d1113248_o.jpg</a>
Scotland Male View RyanK's Pure Silver & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jan 8th, 2008, 10:38 AM   #4 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
I run et45s on 215/45s on -35mm and they dont rub. I knew folks running -35mm on 215/40 17 with Et38 and they didn't rub except a little on the rears when under full power with weight in the back seats.
Old Jan 8th, 2008, 03:36 PM   #5 (permalink)
aml
aml's Avatar
people have said et38 with 205/45 tyres rub, so et38 with 205/40 tyres should rub less or not at all, would that be correct?
thanks so far
Old Jan 8th, 2008, 04:01 PM   #6 (permalink)
Richard Crofts
THE STICK
I'd say that is a fair assumption to make. Like I said I run et45 with 215/45 and they only rub at the rear, and only if theres weight in the back and under acceleration as it goes onto full travel on the spring. I recon my fronts could easy have et38 without an issue and the rears could go to 42 or maybe 40.... and 215/45 are big assed tyres compared to 205 or 215/40
Old Jan 8th, 2008, 04:53 PM   #7 (permalink)
aml
aml's Avatar
thanks richard crofts, i think if it rubs at all, it won't bother me enough to be a problem, so it is what i will be going for i think, thanks
Old Jan 8th, 2008, 05:02 PM   #8 (permalink)
BigShow300
Banned
I've got 215/45/17 ET38 TD 1.2's on my MCS which has the sports suspension and the back wheels do rub on bumpy roads even with just me in the car. If you're not getting a BBK then I'd stick with ET45, plus I had to wait nearly 3 months to get mine in ET38 so make sure if you do get the ET38's they have them in stock.
That said I like the squat stance it gives the car on ET38's. I'll be changing to 205/40's next time which might cure the rubbing.
Visit my Blog at the Motorcade   Reply With Quote
Old Jan 8th, 2008, 06:15 PM   #9 (permalink)
Lucky Dave
Thinking Minis
Im running 225/35/18s on 18x8.5 rims!!
The ET worked out at around 36 due to the width and I needed much modding to get them in!
Lucky is a way of life (tm) 243.5 bhp & 205.3 ft lb
Best 205/45R17 OR 215/40R17 Tyres and wheels??? (non r/flats) aml Wheels, Tyres & Brakes 9 Jan 10th, 2008 09:05 PM
17x7 ET40 with 205/45's and lowered, any rubbing? maxdude Wheels, Tyres & Brakes 4 Jan 19th, 2005 01:50 PM
235/40R17 is it possible? minimc Wheels, Tyres & Brakes 10 Jun 14th, 2004 04:23 AM
ATP ALP 17x7.5 Brett1 Wheels, Tyres & Brakes 3 Mar 29th, 2004 07:44 AM
215/40R17 Continental ContiExtremeContacts Qui Conduit Wheels, Tyres & Brakes 10 May 31st, 2003 09:29 AM
