| Back to front wheel swap Hi, I want to swap my rear wheels to the front as they have been on there for 7 months and are getting worn down ( jcw 210 say no more!). So do I take them to a reputable garage and get them swapped round and do they need re-balancing?? They are 17" bullets with runflats. Any idea of what this would cost or is it a simple swap without any need for balancing?? Cheers |
| By rotational do you mean that they have to turn in the one direction and this would be marked on the tyres wouldn't it?? They are dunlops so I would have to obviously make sure they are going the right direction. So there is definitely no need for them to be re-balanced once swapped?? I see what you mean Scottyboy but just trying to make sure they all wear down evenly and if needs be in the future I will replace them all. |
| Hi, It is safe to do this yourself. Loosen the nuts before you jack the car up. Get the car on a flat piece of conrete / tarmac. Put the jack under the front jack point. Ideally put a chock / piece of wood / brick in front of the opposite front wheel, leave the car in gear with the handbrake on. Jack the car up until the front wheel gets of the ground. Then keep going with the jack and eventually the rear wheel will come of the ground as well. Take the wheels off, and swap front to rear. Then repeat for the opposite side. Remember to torque up all the bolts ![]() Just remember, rotating tyres doesn't overall increase the life of a set of tyres. A tyre has a finite amount of tread to wear down, and on the mini that can be either worn down quickly on the front wheel or slowly on the rear wheel. Rotating can keep the wear amongst the 4 tyres even, so they need replacing at the same time. Cheers Robbo Mods: GO MADDIE and SPARKY! |
| Tags: jcw |
| the back of my front seats :) | LoDRpR | First Generation Faults & Fixes | 5 | Dec 7th, 2007 08:30 PM |
| New front passenger grab handle - swap for another side visor? | lightbody | First Generation Interior & Ice | 13 | Jul 9th, 2006 08:42 AM |
| MCS front and back bumper on MC | ecylai | First Generation MINI Exterior | 11 | Apr 21st, 2004 02:50 AM |
| Will Swap my 2poke wheel for your 3spoke wheel... | JamesBond | First Generation Interior & Ice | 0 | Apr 5th, 2004 10:39 PM |
| Wheel swap, good or bad choice? | SCB | First Generation MINI Cooper S | 21 | Mar 9th, 2004 09:02 AM |
