Runflats VS Normal Tyres - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 21st, 2008, 11:34 AM
mini33's Avatar
Perfectionist Cooper S
Local Time: 03:07 AM
United Kingdom Female View mini33's Classified Ads
DIY Runflats VS Normal Tyres
Sorry yet another runflat question
I have read the many threads about runflats vs normal tyres & am swaying towards normal tyres but have a few issues still swaying me
Consid this is my first mini & first car with runflats i am new to this depate
Against Runflats
1. Tyre pressure checking on average twice a month & judging on how accurate on inacurate they may be the garage one can be this is annoying but a must
2. The thought that if i do use the runflat for the purpose its intended & then the thought of having to fork out for a new run flat after this, surely this is not on as that the purpose they were designed for!!! & there not cheap.
3. The many comments about runflats & there dislike to pot holes but this will also be the case of non runflats though. Also the price of repair that my friends has just had to folk out for her mini after a pott hole disaster.
4.& many more but that just a few
Against normal tyres
1. The non ability of driving on flat & the damge that can be done as i drove flat before!!
2. The thought of being stuck in the country lanes on the way to work with a flat & waiting for recovery -(
3. The thought of having no spare & no space to store a spare
4. Will the run flat system accept non runflat tyres.
5. Will the handeling/cornering be as got with normal compared to runflats
6. etc
Also would the change affect my insurance as my policy is due this weekend & will i have to notify them of the possible near future change
Any tips or your thoughts on what i should do than that will be appreciated as i'm a mini novice mechanic but learning slowly
Old Jan 21st, 2008, 03:19 PM
MINIAC's Avatar
Canned
Local Time: 08:07 PM
Checking tire pressure on a regular basis should be done regardless of what type tire you're running. Tires which aren't inflated to the proper tire pressure wear unevenly and have a shorter life.
The TPMS works for either run flat or conventional tires.
Old Jan 21st, 2008, 10:30 PM
super c00per's Avatar
MiNi2 dEmOn
United Kingdom Male View super c00per's Electric Blue & White 1st Gen MINI Cooper S Profile
im in the same boat mate!!! just pricing up tyres this week!!
Old Jan 22nd, 2008, 07:55 AM
batou's Avatar
Turbo Schmurbo...
United Kingdom Male View batou's Dark Silver & Black 1st Gen MINI Cooper S Profile View batou's Classified Ads
Against Runflats
1. Tyre pressure checking on average twice a month & judging on how accurate on inaccurate they may be the garage one can be this is annoying but a must
You should check them more often that that anyway.
I didn't have time to wait for a internet price and had to replace a runflat at a local tyre shop. £160 per corner, nice! You can't even repair them either
Pot holes will still do the same damage regardless of tyres.
Ride quality is equivalent to concrete too..
Y
ou still can! One can of holts tyre weld and a compressor in the boot...
... for situations like above when you can't wait for recovery.
Again, tyre weld for emergency situations.
There is no "run flat system" as such, yes the runflats fit the rims and yes they work with the pressure sensor, but then so do normal tyres.
I changed to Goodyear Eagle
GSD3 215/40/R17 and I wouldn't believe someone who said this but seriously, the handling in damp conditions is probably as good as the dry handling was with Pirelli Euforia Runflats!!! Handling is massively improved.
I also saved 5KG's of unsprung weight switching to the 215/40 profile. Turn in is still just as sharp but the grip is monumental,
my MCS has 30/40hp up on standard and has less understeer than it did with runflats and less power!!!
6. You can repair some puntures on normal tyres rather having to bin the whole tyre.
7. Much cheaper I can get 4 top end Goodyears for less than two Dunlop/Pirelli runflats.
8. Ride quality is much improved, doesn't crash into bumps. Less bang and more thud if you get me?
9. Better braking, improved grip and a little more flex in the tyres help braking.... a lot.
When talking fails, it's time for violence. ~ batou.
Old Jan 22nd, 2008, 03:34 PM
mini33's Avatar
Smile
I realise that but every two weeks or less is a bit ott isn't it
Old Jan 22nd, 2008, 03:40 PM
mini33's Avatar
Quote: Originally Posted by batou (original)
Against Runflats
Pot holes will still do the same damage regardless of tyres. Ride quality is equivalent to concrete too..
You still can! One can of holts tyre weld and a compressor in the boot...
I changed to Goodyear Eagle GSD3 215/40/R17 and I wouldn't believe someone who said this but seriously, the handling in damp conditions is probably as good as the dry handling was with Pirelli Euforia Runflats!!! Handling is massively improved.
I also saved 5KG's of unsprung weight switching to the 215/40 profile. Turn in is still just as sharp but the grip is monumental, my MCS has 30/40hp up on standard and has less understeer than it did with runflats and less power!!!
THANKS FOR THAT THERE SOME USEFULL INFO THERE, I LIKE THE THOUGHT OF SOME GOODYEAR EAGLE F1'S AS I HAD SOME OF THEM BEFORE IN 16INCH & LIKE THEM
I WILL NEED SOME THAT ARE AS GOOD IN ALL WAETHERS AS I DRIVE IN ALL WEATHERS & ALONG COUNTRY LANES
I THINK I NEED O BUY SOME OF THAT FLAT TYRE STUFF & KEEP THAT IN MY BOOT!!!
Old Jan 22nd, 2008, 03:43 PM
MINIAC's Avatar
Canned
I'll check the tire pressure before I do a long roadtrip or once a month if I'm not driving a lot of miles.
Old Jan 24th, 2008, 11:21 AM
Mark84's Avatar
United Kingdom Male View Mark84's British Racing Green & Black 1st Gen MINI Cooper Profile View Mark84's Classified Ads
Im also considering wheel options at the mo! just got my mini last week and its on 16" runflats (dunlops) but was considering my options for 17" alloys with normal tyres once ive worn these out!
Went to a local tyre shop that i know and trust and he said that he thought that the cars suspension is set up to suit the harder runflats and that if changed to new alloys with normal tires the handling would suffer owing to the more supple suspension designed for runflat tyres? is this true? he also mentioned the no spare wheel issue but like has been said above a nice can of tire weld and your away! any help much appreciated!!
Old Jan 24th, 2008, 11:46 AM
mini33's Avatar
My sentements exactly Mark thats my thoughts but dont seem to be getting any usefull answers
Hopefully we can both get answers
Old Jan 24th, 2008, 02:06 PM
batou's Avatar
Turbo Schmurbo...
"Owing to the more supple suspension", has this tyre shop ever driven a mini? The ride is about as subtle as a brick in the small of my back !!!!! It's set up hard and then made even harder with run flats. I'm sorry, although having driven 5000 miles on runflats and just 2000 miles on non runflats I still think I can comment on this.
If you read bmw mini marketing blurb it refers to the car being one of if not the stiffest chassis on any supermini!!
The handling has not suffered in anyway possible. Yes the car was designed to get the best from bmw's insistence on using runflat tyres on their cars but it only mean that there car will benefit even more when using performance tyres. All cars are designed with a certain tyre in mind but using a better all round tyre than what the car was based on is not ever going to be a bad thing.
The only thing I could say is the runflats are very stiff and have no give, real tyres do so they flex which slow down turn-in but increase grip. The turn in can be countered by going for a lower profile (40's) like i did.
On every car I've owned I've been picky with tyres and the first thing I felt uncomfortable with was the grip in wet weather when running on runflats. Lets just say thats now gone
Please don't let my slight dyslexsic'ness give you the impression i'm uneducated !
Old Jan 24th, 2008, 02:10 PM
Mark84's Avatar
An Answer!!
Ok according to the local mini dealers tyre specialist aftermarket wheels will be fine provided the tracking is all done properly afterwards!
As far as he was aware the suspension set up is no different for non runflats to runflats! so apart from the difference in the wheels themselves the ride should be no different!
I'm likin these form my BRGreen mini with its black roof and wing mirrors!
17" MINI WROX ALLOY WHEELS & TYRES COOPER S MINI 1 on eBay, also, Wheels with Tyres, Car Wheels, Tyres Trims, Cars, Parts Vehicles (end time 25-Jan-08 16:56:08 GMT)
Hope this helps, if someone knows different though to what i have been told please correct me!
Old Jan 24th, 2008, 02:19 PM
batou's Avatar
Turbo Schmurbo...
No wonder!!!! After market wheels will alter the characteristics for sure, I was talking "Runflats VS Normal Tyres" were now talking Standard 16s plus runflats vs aftermarket 17s plus non runflats???
If were talking just tyres then my above comment is true, if its tyres and different wheels, weights, and different fittings then I can't help.
Old Jan 24th, 2008, 02:27 PM
Mark84's Avatar
sorry batou didn't see your previous post to my reply! yeah i have to agree wholly on what you said! and i definatley agree on the grip aspect. i had goodyear F1's on my last car and although the car had a lotus handling setup the tyres were awsome and i miss them soooooo much! i think once ive had some fun on these tyres and worn them out a little i'll be going back to my goodyears!
Old Jan 24th, 2008, 09:12 PM
MiNi2 dEmOn
So according to you batou running 40's is better than 45's???
Has anyone else found this, or what would you recommend??
  #15 (permalink)
Old Jan 25th, 2008, 07:20 AM
batou's Avatar
Turbo Schmurbo...
Well what I mean is, running 215/40/R17 Goodyear Non-RF's is better than 205/45/R17 Pirelli/Dunlop RF's.
I would guess, not from experience, that turn in maybe slightly slower with 215/45/R17 Goodyears because of the increased profile and added flex, and also the extra 1.3Kg per tyre (215/45 are 22lbs, 215/40 are 19lbs).
However, the ride will be even better still with 215/45/R17.
Tags: , , ,
From Runflats to normal tyres? AberdeenMini Wheels, Tyres & Brakes 15 May 24th, 2008 03:17 PM
2 x runflats 2 x normal tyres... problem? jasonfields007 Wheels, Tyres & Brakes 7 Aug 18th, 2004 08:49 PM
Replacing MCS Runflats with Normal Tyres - Guaranteed No Punctures (UK) NEMINI Wheels, Tyres & Brakes 14 Aug 19th, 2003 02:21 PM
Runflats > then 'normal' tyres GTT 280 Wheels, Tyres & Brakes 3 Mar 17th, 2003 08:16 PM
