Visit Out Motoring!
Tags: ,
Old Feb 4th, 2008, 06:12 PM   #1
kmpowell
kmpowell's Avatar
Local Time: 03:31 PM
Question The 'Perfect' ET(Offset) for 18" on a R56 MCS?
A simple question really, but I'm looking at some 18" lightweight wheels for my 57 plate MCS. From what I have read the 17's that come on it are ET48, and the JCW 18s are ET52. Both are 7" wide though?
Now, having seen a few Works wheel equipped R56 MCSs knocking around I have always thought they looked a bit shallow and indented (just a personal opinion, no offence intended), so would I be able to get away with a 7.5 and a lower offset (say ET45/48), or is there a reason why the JCW wheels are the same width as the 17"s?
No doubt once I have the above sorted I shall have other questions re tyres.
Speeding has never killed anybody, suddenly becoming stationary... that's what gets you!
Old Feb 4th, 2008, 06:53 PM   #2 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
all depends on your brake kit and the wheel itself - width of, and interior spoke design etc.
So there is no "perfect" ET for an R56.
Old Feb 5th, 2008, 07:00 AM   #3 (permalink)
kmpowell
kmpowell's Avatar
The brakes are the standard OEM setup (for now), however as I only do the odd track day a year, the only upgrade I can ever see happening in that dep't is upgraded pads & discs.
Old Feb 5th, 2008, 09:38 PM   #4 (permalink)
Damo
MINI2fosi
Damo's Avatar
Send a message via MSN to Damo
The offset of 52 for the R53 is ridiculous. (I run 42 rear, 34 front). The R56 should have even more clearence for 8" wheels (8" is doable on the R53)
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 6th, 2008, 07:37 AM   #5 (permalink)
kmpowell
kmpowell's Avatar
Thanks Damo, I have decided that the max I would want to go is 7.5" width, however the offset is still troubling me a bit. I'm thinking a max of ET40 might be doable, but feel that may be pushing it to the limit?!? I've also asked a couple of wheel dealers to quote me what they think will be the best fitment for the wheels I have chosen.
Old Feb 6th, 2008, 08:24 AM   #6 (permalink)
Damo
MINI2fosi
Damo's Avatar
40 would be a bit of a squeeze at the rear (outside edge) on an R53 and have a bit of rubbing, but should be fine for an R56. I think it was the fireball guy that said there is loads of room for big wheels on the R56.
Old Feb 6th, 2008, 08:53 AM   #7 (permalink)
kmpowell
kmpowell's Avatar
Hmmm, I think he may be right, this is what the rears on my car look like (17" flames on SS)...
Last edited by MINIAC : Feb 6th, 2008 at 03:17 PM. Reason: Make images clickable thumbnails
Old Feb 6th, 2008, 09:35 AM   #8 (permalink)
Damo
MINI2fosi
Damo's Avatar
Forgot to mention in my other post, I was talking about a lowered R53.
7.5" ET40 on a standard height R56 should be more than fine!
Old Feb 6th, 2008, 12:16 PM   #9 (permalink)
kmpowell
kmpowell's Avatar
I think 7.5" somewhere on or between ET40-45 is what I'm going to go for. I just need to sort out what tyre dimensions to go for now! Any suggestions, 215/35/18?
Old Feb 6th, 2008, 01:11 PM   #10 (permalink)
Damo
MINI2fosi
Damo's Avatar
215/35 R18 OR 225/35 R18. Also depends a lot on the tyre. I have 215/35 R18's Yoko;s and they're very wide. Wider I'd say than some other makes of 225/35 R18's (toyo's defo!)
18" alloys offset? addz Wheels, Tyres & Brakes 7 Jul 6th, 2007 02:32 PM
215/45/17 with VOlks CE28N 43mm offset and M7 Sports Spring - "DOES IT RUB"??? ilovepanerai Wheels, Tyres & Brakes 2 Nov 16th, 2004 04:59 PM
18" with 42 offset? stationwagon278 Wheels, Tyres & Brakes 4 Jun 24th, 2003 09:45 PM
Whats the "Perfect" Aftermarket Head Unit for a MINI? AidenL Interior & Ice 92 Dec 7th, 2002 07:50 PM
17" wheel offset lotatoys Engine & Drivetrain Tuning 5 Apr 12th, 2002 09:00 AM
