| Tags: 17x75 r17, 20545 r17 |
| MINI2 Regular | How much difference is it 205/45 vs 215/40? Hi! I want to know if someone use 205/45 R17 tire on a 17x7.5 inch wheel. Standard is to use this tire on a little narrower wheel such as 17x7. Will it be fine using 17x7.5 instead? Is it easy to damage the rims with this combination and other possible problems? I want to use 205/45 since the speedo will be the most accurate and it is used by MINI. |
| | #9 (permalink) |
| MINI2 Regular | Miniac Yes that is true lol, this is hard indeed, I wish I had found some rims with higher ET. Thanks for your concearn MINIAC, I should probably use 205/45 but I am afraid it will be a harsh ride .But I think it will look better with 205/45 since it will stick out less and like you said, risk for rubbing is reduced. I have ordered my wheels online so I have no chance to try before I buy, so I am trying my best to figure out what will work best. I will stick with my order and hope the ride is good although I am used to 175/65 R15 (my old setup) . |
| | #12 (permalink) |
| MINI2 Regular Join Date: Oct 2007 Location: Glasgow Local Time: 04:06 AM
Offline | I changed to get rid of the runflat tyres, stuck Goodyear F1 GSD3s on it. Its a great change, significantly better traction wet/dry ride quality much improved. Only reason to change tyre size was that 205/45 was not available so i went for the 215 section. The tyre fitters said they were a great fit on the wheels s-spokes And the extra width/depth protects the wheels when the wife drives the car ![]() |
| Just a little mod, but what a difference :D | Ingrid | General Discussion | 87 | Mar 24th, 2006 09:50 PM |
| What is the difference | MikeHendrick | General Discussion | 0 | Feb 8th, 2006 07:56 PM |
| 205 45 v 205 40 Does someone know the difference | MickPad | Wheels, Tyres & Brakes | 5 | Dec 10th, 2004 03:23 PM |
| US and CDN Difference | BBMini | Canada | 5 | Aug 28th, 2003 12:10 AM |
| Does anyone know the the difference between... | Jett Black | Wheels, Tyres & Brakes | 0 | May 16th, 2003 09:30 PM |
