Mini Pirate
Old Mar 10th, 2008, 12:18 AM   #1
pisquano
Local Time: 10:32 AM
Unhappy am I going crazy?
hi there
I replaced my 2 front tyres and had the alignment done..
prior to that I had the impression the car was slowly pointing right... after the job everything seemed fine BUT....
at times I still have the impression the car sliiiightly tends to go right...
how and what could I still check? maybe the camber?
any ideas? it's not major of coure but I just want to be 100% sure the car hasn't got a steering problem
Old Mar 10th, 2008, 12:19 AM   #2 (permalink)
NeuroBeaker
Where's my navigator?!
NeuroBeaker's Avatar
The MINI does seem extremely responsive to road camber. If you're driving on a Motorway, do you still get the same effect?
NeuroBeaker
Proud owner of "Zeus" (a 'slightly modified' 2004 Mini ONE).
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Mar 10th, 2008, 01:18 PM   #3 (permalink)
Darthbladerni
Mini Youngster
Darthbladerni's Avatar
Could be the camber on the road.
Infact, when your driving along with the car going straight, is your steering wheel slightly off??
Mine was when i first got mine alligned, it was a couple of degrees off to the right but i got it fixed. It made me think it was puling when it wasnt.
Northern Ireland Male View Darthbladerni's Liquid Yellow & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Mar 10th, 2008, 03:11 PM   #4 (permalink)
pisquano
sorry can you elaborate?
when i drive on perfect straight and even road I have the impression it's fine..(I tried on a Tesco parking space which was flat)
I just notice that the majority of times when I have to correct the steering is because the car is going on the right.. 90% of the times... not a lot but still to the right..
how did you fix your problem? did you have another alignment done? did you fix the camber or something else?
thanks
Federico
Old Mar 10th, 2008, 03:14 PM   #5 (permalink)
pisquano
Angry
haven't driven on motorway only central london...
in fact when I drive on the left side of a "cambered" road the mini instantly leans to the left and viceversa...
but on flatter roads where it should stay central it really feels it's drifting to the right...
maybe Kwik fit didn't do the alignment properly?
Old Mar 10th, 2008, 03:18 PM   #6 (permalink)
Hugo
Hugo's Avatar
i would check tyre pressures then check bushes in the suspensions arms then if their ok get the wheels realigned.
Northern Ireland Male View Hugo's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 10th, 2008, 03:37 PM   #7 (permalink)
pisquano
the front tyres are new so I would think pressure is fine.
What pressure should I have in the back tyres?
How do I get bushes checked?
thanks!
Old Mar 10th, 2008, 03:55 PM   #8 (permalink)
Hugo
Hugo's Avatar
I would check them anyway, I run mine about 30-32psi.
Mechanic would check the bushes. Jack the car up and shake the wheel to see if theres any play in it.
Old Mar 10th, 2008, 04:05 PM   #9 (permalink)
pisquano
I will ...also one day after changing them the run flat tyre indicator goes red (no flashing).
i thought it was normal after a change so I reset the system...
Old Mar 10th, 2008, 04:24 PM   #10 (permalink)
Hugo
Hugo's Avatar
Yep.
sat nav gone crazy! polak-2004 Faults & Fixes 5 Feb 3rd, 2005 03:59 PM
help me! I am still crazy! mrhollio General Discussion 5 Feb 8th, 2004 02:42 AM
PDC gone crazy! xnetco Faults & Fixes 3 Feb 24th, 2003 09:47 AM
