Old Apr 2nd, 2008, 11:36 AM   #1
schroedm
schroedm's Avatar
Local Time: 04:15 AM
Unusual Tyre Wear Question
Hi,
Had a quick maitenance service yesterday with a view to getting through an MOT and one unusual thing came out.
The rear tyres were worn from 6mm on the outside down to the cords (in one place) on the inside on BOTH rear tyres. The car has never been in an accident and never done anything more adventurous than drive to the station and back! It's 5 years old.
BMW wanted nearly £300 to KDS (laser alignment check) just to see what might be 'bent'. Open cheque book after that.
I don't believe anything is 'bent' as the car has had an easy life. They suggested pot hole damage but I argued that it was odd for BOTH sides to be 'damaged' exactly the same amount to give the same tyre wear both sides.
To my mind it could be some sort of suspension bushes that are worn causing the car to squat down slightly and thus put extra pressure on the insides of the rear tyres??!?!?
Has anyone had this or come across it?
Thanks,
Mark
Old Apr 2nd, 2008, 01:09 PM   #2 (permalink)
adam_Randell
07' Cooper
adam_Randell's Avatar
Send a message via MSN to adam_Randell
Check your tyre pressure isnt too high, if it is the extra pressure will create a camber on the top of the tyre causing it to wear unevenly.
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Apr 2nd, 2008, 01:13 PM   #3 (permalink)
schroedm
schroedm's Avatar
Am having new tyres fitted tomorrow and will monitor the wear and pressures.
I would have thought that too high pressure would cause the centre of the tire to wear first and too low would cause both sides of tire to wear???
Rgds,
Mark
Old Apr 2nd, 2008, 01:34 PM   #4 (permalink)
Vitesse
Has it had the rear tyres replaced at all in 5 years?
Old Apr 2nd, 2008, 01:43 PM   #5 (permalink)
schroedm
schroedm's Avatar
No. Only done 19000miles but odd thing is the tires have 5-6mm tread on outsides of them?
Old Apr 2nd, 2008, 01:47 PM   #6 (permalink)
jam4knr
Mini Goggles
jam4knr's Avatar
What make are they schroedm?
I had some a while ago and one went down to the cords also, if its the same make i can explain why.
England   Reply With Quote
Old Apr 2nd, 2008, 01:50 PM   #7 (permalink)
schroedm
schroedm's Avatar
17" Dunlop Sport 9000 DSST Run Flats 84V (trips off the tongue eh? )
Old Apr 2nd, 2008, 03:28 PM   #8 (permalink)
billy.batson
Rgds,
Mark
Yes, I would have thought that too, but yours is the opposite. They shouldn't have worn like that in 19000 miles if pressure was correct though.
Old Jun 11th, 2008, 10:46 AM   #9 (permalink)
M.O.S
MINI One Seven
Take it to an independent garage and see what they think is wrong. The chances are it is the tracking or something to do with the suspension - if its been going round town, there is more wear - kerbs, speed bumps etc. However, the wear shouldn't be that extreme - 6mm on one side and down to the threads on the other is some margain.
You could always put new tyres on it and buy a new mini. I know yours hasn't done many miles, but you'll be coming to the end of the service pack anyway.
Old Jun 11th, 2008, 11:08 AM   #10 (permalink)
David King
Captain Slow
David King's Avatar
LOL! A service pack is just over £300, a new car is thousands.
Not exactly the best reason to change a car.
United Kingdom Male View David King's Royal Grey & Silver 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 11th, 2008, 11:14 AM   #11 (permalink)
James@fomsport
MINI2 Sponsor
The MINI dose need a KDS type alignment, but bmw over charge for this, and the system (hunter pro) is available elsewhere the company that sells it has a database of all places in the uk with the system www.AlignMyCar.co.uk
The KDS or Hunter system works buy weighting down certain parts of the minis chassis to achieve a factory preset ride height (by putting 67kg on both front seats, full tank of fuel or weight of, and 14kg in the boot) because the mini has independent rear suspension, all 4 wheels are adjustable, hence the need for the different system rather than a 2 wheel laser alignment.
bmw aren't the only company to use this as their method its also used buy Lotus, VW, Porsche, and Mercedes
its quite possible that your car wasn't set up right out the factory its been known to happen, or it had a 2 wheel laser done at some point ? and because of this they rear wasn't set or checked.
HTH
james
M7's UK Dealer : KW Suspension : Speeline Wheels : Quicksilver : Forge
Old Jun 11th, 2008, 11:26 AM   #12 (permalink)
russyellocoops
having fun or hungover...
russyellocoops's Avatar
Send a message via MSN to russyellocoops
Or a lot more simply Dunlop runflats wear a lot more on th shoulders!!!
United Kingdom Male View russyellocoops's Liquid Yellow & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 11th, 2008, 11:30 AM   #13 (permalink)
James@fomsport
MINI2 Sponsor
yes the old Dunlops were not the hardest wearing tyres and did like to wear on the shoulders.
But i was making a general point about making sure the minis suspension is kept well set up as it is thrown out quite easily, i should know ive had 3 KDS style alignments in the last year after a few pot holes up here bounced things out.
The main cause of the minis suspension getting bounced out is down to the heavy oem wheels and run flats.
Old Jun 11th, 2008, 03:56 PM   #14 (permalink)
M.O.S
MINI One Seven
I know, but 1, if you buy a new car its £150 and two, how much is it going to cost to fix your current car? Minis don't depreciate too heavily, so the fear of depreciation is almost nil. Can you think of a better excuse to change your car!
Old Jun 11th, 2008, 03:58 PM   #15 (permalink)
M.O.S
MINI One Seven
So is it less likely for us with 15" wheels? Sounds like another advantage of the 15s!
Old Jun 11th, 2008, 05:43 PM   #16 (permalink)
Vitesse
James I agree on them not coming out of the factory very well aligned or balanced. I had a KDS on mine, when it was not very old and is was out of spec for one reason or another on virtually every wheel. I can't imagine they do anything as in depth as a KDS before it leaves the factory?
How much would you expect to pay for an independent to do a KDS?
Old Jun 11th, 2008, 05:54 PM   #17 (permalink)
Vitesse
[quote=James@fomsport;3462936]The MINI dose need a KDS type alignment, but bmw over charge for this, and the system (hunter pro) is available elsewhere the company that sells it has a database of all places in the uk with the system www.AlignMyCar.co.uk
Whoops I searched for my local company who do KDS but it came up as a Bentley Dealership who would probably charge double what BMW do, but at least the accept the £5.00 off voucher
Old Jun 11th, 2008, 06:35 PM   #18 (permalink)
James@fomsport
MINI2 Sponsor
lol most of them should be inide garages or tuners, which would charge between £60-£160 at the most, if you think paying bmw £300 is scary porsche have been know to charge over £500 for it
Old Jun 11th, 2008, 07:15 PM   #19 (permalink)
David King
Captain Slow
David King's Avatar
Im sorry to disapoint you, but no MINI has no depreciation!
Tyres will wear out on the new car aswell!
A good excuse for changing a car is wanting a new car, not just because the tyres wore out on the old car!
Old Jun 11th, 2008, 07:24 PM   #20 (permalink)
M.O.S
MINI One Seven
I know that Minis dont have £0 depreciation, but according to Parkers they are the slowest depreciating car you can buy.
I know that tyres will wear out on a new car aswell, however, I was saying get a new car because of the tracking/suspension fault, which by many accounts is going to be expensive to fix.
Unusual question...is this idea crazy? NeedMiniInfo General Discussion 19 Apr 2nd, 2008 08:28 PM
Tyre Wear daro911 2nd Gen MINI Cooper S 16 Feb 19th, 2008 06:22 PM
tyre wear kak Wheels, Tyres & Brakes 3 May 2nd, 2006 08:31 PM
Unusual question: SLK to MCS mini_luso MINI Cooper S 14 Apr 30th, 2004 04:03 PM
Tyre wear on ONE? yellow peril Wheels, Tyres & Brakes 5 Feb 15th, 2003 01:14 PM
