Visit Derek Woodman MINI
Tags: , , ,
Old Apr 29th, 2008, 10:01 PM   #1
Hugo
Hugo's Avatar
Local Time: 02:00 AM
Works brake ain't working
Have a problem with brakes. The 1st press of the brake pedal, the pedal goes nearly to the board then the 2nd press straight after is excellent. leave it for 10 secs the pedal goes back to the board. Ran litres of fuild through them and checked for leaks, nothing.
Fittted;
JCW Cailpers and pads
R56 cross drilled discs
EBC rear discs
Mini rear pads
Goodridge brake hoses
Fitted front Calipers with discs and pads on Saturday bled the brakes which carried onto Sunday.
Rear discs and hoses arrived last yesterday fitted last night and today but the brakes are still the same as the weekend, hardly anything on 1st press of the pedal then the brakes are excellent on the 2nd. Then leave the pedal for 10secs it goes soft again.
Left it into mechanic today, who drained the 5.1 and replaced it with dot4, and they couldn't get it working. They suggested putting clamps onto the pistons then press the foot brake and if the pedal went to board it would be a Master cylinder. And it did, master cylinder is £150.
Has anyone got any other ideas before I buy a Master Cylinder?
Northern Ireland Male View Hugo's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 30th, 2008, 07:01 AM   #2 (permalink)
r1_kde
JCW 210 "apparently"
r1_kde's Avatar
I know this will sound stupid but have you fitted them the correct way around with the bleed nipples at the top? if you have not then there is always an air block, this air block can't be removed if the caliper is upside down even with pressure bleed.
just check that the nipple is at the top of the caliper. simple but easy to make that mistake, if it is try us again.
My gut feeling is your caliper is the wrong way up or wrong way around
Old Apr 30th, 2008, 08:51 AM   #3 (permalink)
Hugo
Hugo's Avatar
Thats what it is then, they are on upside down. Way to buy more brake fuild!
Old Apr 30th, 2008, 10:02 AM   #4 (permalink)
r1_kde
r1_kde's Avatar
Hope thats helped you then! you should only need to bleed for a few mins till firm. when done you will notice that the barakes are not that good, they will be fine after you have bedded them in. I hope you did not draw any air back in when pumping...
should be a cheep fix! and only should take about 30mins to do.
Old Apr 30th, 2008, 09:58 PM   #5 (permalink)
Hugo
Hugo's Avatar
Thanks r1_kde that fixed it only took a few pumps of the pedal and each one was firm plus I got 5.1 into the system again. Couldn't believe it and braking power is superb, it feels like the rear bumper is going to pass the front bumper.
Which AFTERMARKET brake pads will be compatible with brake sensors? wrxtomini Maintenance & MINI Care 0 Apr 22nd, 2006 03:17 PM
both brake lights are not working hamster100 Faults & Fixes 5 Jan 13th, 2006 02:03 PM
HELP Rear Brake Lights are not working JpMcC Faults & Fixes 1 Jun 29th, 2004 10:59 PM
new alloy and tyres will i need to get new brake discs and brake pads TREBALZ Wheels, Tyres & Brakes 7 Sep 23rd, 2003 11:24 PM
A/C Not Working; Aux Cooling Fan Works Too Well! tomstork Faults & Fixes 4 Jul 30th, 2003 07:27 PM
