Wipac
Tags: , ,
Old May 1st, 2008, 01:45 PM   #1
mcs_jcw
mcs_jcw's Avatar
Local Time: 12:55 AM
Rubbing problems with new wheels
I'm about to buy a new set of rims.
I've been reading about offset and so for a long while but I can't figure out if my new rims once assembled will give some sort of rubbing problems.
The new wheels will be 7x17 with ET37. Tyres: 205/45/17 Bridgestone Potenza RE050A W.
I've got a friend who says he has had problems with his R90 replica as the ET is 40. Also 7x17.
Let's hear the voice of the experience this time.
At least, the garage allows me to try the wheels for a while to see if this problem happens.
Let you know to sort out this problem to someone else in the same situation.
Catalonia Male View mcs_jcw's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 1st, 2008, 03:56 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 05:55 PM
Online
Is your MINI lowered?
Old May 1st, 2008, 04:30 PM   #3 (permalink)
Darthbladerni
Mini Youngster
Darthbladerni's Avatar
Local Time: 01:55 AM
i think they will be ok.
I mean if 18x7.5 with 215x35 tyres with an offset of 43 fit and lowered im sure you will be fine.
Northern Ireland Male View Darthbladerni's Liquid Yellow & Body Color 1st Gen MINI One Profile   Reply With Quote
Old May 1st, 2008, 05:37 PM   #4 (permalink)
PmP
GP 06 MCS 0380
PmP's Avatar
Is it a R50/R53 or a R56 Model Mini?
I had rubbing with ET48 17x7 wheels, with 5mm spacers, and 205/45/17 tyres, just on outer edge of tyre and the plastic arch lining, but my R53 is lowered over an inch.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 1st, 2008, 07:05 PM   #5 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
The thread originator has a icon on his post
Old May 2nd, 2008, 01:44 AM   #6 (permalink)
mcs_jcw
mcs_jcw's Avatar
I've got a R53 JCW. I'm about to get a new rims and a month later I'll get the coilovers.
So, I don't want to get any problems then.
I know I'll be using 205/45/17 Bridgestone Potenza RE050A.
And I know I won't get the car lowered more than an inch at the front and a bit -0,8 inches at the back when I get the coilovers.
Hence, which is the right ET for a set of 7x17 wheels not to get problems of rubbing?
Also, I must say my Mini has got a set of Wilwood BBK assembled so I need some space to fit in.
New wheels & tires, getting rubbing - best solution? Sigfrund Wheels, Tyres & Brakes 0 Jun 3rd, 2007 07:11 PM
jcw wheels rubbing? grantw Wheels, Tyres & Brakes 3 Jan 22nd, 2007 02:38 PM
Custom Steering wheels, problems? MetalMiniMayhem Interior & Ice 13 Sep 21st, 2004 03:05 PM
HELP! Why are my wheels rubbing the arches? TT_Convert Wheels, Tyres & Brakes 3 Sep 7th, 2004 08:16 PM
Found out the hard way...... (problems fitting 15" wheels to Cooper S) CSDan Wheels, Tyres & Brakes 13 Nov 5th, 2002 10:20 AM
