| Tags: braided, difference, goodridge |
| Specialist in Everything Join Date: Mar 2008 Local Time: 08:15 AM
Offline | Hi, I have a 2002 MC and I ordered a Goodridge brakeline kit off eBay. Goodridge's catalogue states that there are two kits available for the Mini- one for cars up to Sept 2003 (SBW1100) and one for cars from Sept 2003 onwards (SBW1150). So I ordered the SBW1100. Well lo and behold, after a 2-week wait the kit finally arrived.... the WRONG kit. I told the seller, and he said "I was told they are both the same kits by Goodridge - is this not the case?" I find it hard to believe that Goodridge would bother with two separate part numbers for the same kit. And I don't want to dismantle my car, only to find out that they're NOT the same, Plus doing so would mean that this kit would be dirtied and not returnable. So I beg of anyone out there who might have experience of both kits - ARE they interchangeable? What's the difference between them? Any help would be very much appreciated! Jonathan "They might be drinkers, Robin, but they're people too" - Batman, 1966 |
Offline | The answer I went to the effort of jacking the car up, removing wheels and comparing my rubber hoses to the newer Goodridges. Of course, it's only the day AFTER I go to all the effort, that I realise I could've looked up the parts on the feckin' BMW ETK application and spotted the difference without leaving my seat... ![]() Ugh, if I had brains I'd be dangerous. The pre- and post- 09/03 kits are NOT interchangeable. The front hoses are unchanged, but the fitting at the caliper end of the rear hoses is different. On the older hose, there's a banjo fitting on the caliper end. On the newer hose, it's a screw fitting. ![]() NOTE: Goodridge's catalogue states the changeover date as being September 2003. However, the ETK program states the changeover date as being APRIL 2003. Consequently, if I were an owner of any 2003 Mini, I'd take a couple of minutes to check which type of fitting my rear hoses used before I ordered anything. "They might be drinkers, Robin, but they're people too" - Batman, 1966 |
| MINI2 Master Join Date: Dec 2002 Location: Malmesbury, Wilts Local Time: 08:15 AM
Offline | Goodridges are wrong, there where changes in Sept 03 but not to the brake hose fittings. I have a mid Sept 03 car so built late August/early Sept and it has the later fittings. You are correct though to be safe always check your own car. ![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
| MINI2 Master Join Date: May 2006 Location: Norn Iron Local Time: 08:15 AM
Offline | Sorry I'm no help with this but I would try Lohen and ask them. Make sure you have a copper washers on each side of the banjo and the nuts for GR hose and the brakes pipe have been tightened with two spanners to prevent leaks. I fitted them last week with JCW calipers, R56 cross drilled 294mm disks and rear ebc turbo disks and pads with 5.1dot fuild, what a difference, touch the pads it slows down wee bit more and it stops dead. I did it all for £50 cheaper than buying a R53 JCW brake kit fitted from the cheapest dealer. ![]() |
| Pre or Post Facelift Help!!? | joshie | MINI Cooper S | 13 | Mar 13th, 2008 02:07 PM |
| pre 02/02 vs post 03/02 mini suspension | jksgoh | Suspension | 4 | Jan 2nd, 2008 12:40 PM |
| What short shift kits are the best for pre 04 mini. | fozworth | Engine & Drivetrain Tuning | 2 | Sep 10th, 2006 03:20 PM |
