Carccessory.com
Old May 15th, 2008, 06:32 PM   #1
Jinkster
Local Time: 10:45 AM
Fitting brakes to MINI One
I have bought some pads to fit to my MINI One as the wear inidicator is on. Do you I need to change the sensor to enable the light to switch off??
Old May 15th, 2008, 07:06 PM   #2 (permalink)
Geoff104
GGA S
yYs, new sensor required (Or sensor needs to be bypassed using old sensor wires) for warning light to be extinguished. Effectively the sensor is a wire loop which is broken when the pads wear to their minimum thickness. Ebay is usually a good source of replacements.
Old May 15th, 2008, 07:08 PM   #3 (permalink)
Jinkster
what would you do? bypass or buy some more.
Old May 16th, 2008, 06:56 PM   #4 (permalink)
SteveM3
SteveM3's Avatar
Bypass is cheaper and easier but then you will need to check your pads from time to time. If you let the pads wear down until they set off the sensor then it shows you need the sensor. So I would recommend a new sensor .
England Male View SteveM3's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
fitting r56 brakes on an r53 toofast Wheels, Tyres & Brakes 2 Aug 23rd, 2007 02:30 PM
Fitting Brakes Foxy Mini Wheels, Tyres & Brakes 10 Nov 19th, 2006 07:42 PM
MINI Spec for Brakes Mini Steve Wheels, Tyres & Brakes 3 Jun 15th, 2006 01:54 PM
Need help on fitting brakes Lee e Wheels, Tyres & Brakes 1 Sep 11th, 2005 06:26 PM
MINI brakes MINIMiller General Discussion 14 Jan 17th, 2002 11:56 PM
