| | LinkBack (10) | Thread Tools | Rate Thread |
| Hi -thinking of fitting the BBK's to my 04 MCS JCW. Some questions: 1. What spacer size is required for 17" S-Spokes? 2. Would doing the fronts only be a big problem in terms of brake balance. Not too keen on cutting away a bit of the trailing arms? 3. On the R56 is states that a software reset is required for the ABS, have not seen any comments about resets on the R53, probably no upgraded sw available in any case 4. Other option is to fit the R53 JCW sport brake kit, advantage is that no new hoses or mods are needed - is this option really a waste of time now that the Brembo's are available? Thanks for any comments |
| I am starting to reach the same conclusion, R53 JCW kit. Read an interesting article on NAM concerning brake bias front/rear. The new JCW Brembos has not been engineered for the R53, on the R56 according to the install pdf an software upgrade needs to be loaded to ensure the ABS/ABD etc work correctly. Not too keen on spacers and doing fronts only, rear installation also has its issues. Coming up to a disc & pad (fronts) replacement soon, would then be the time to put in the R53 BBK. Big or rather huge in the case of the Brembos is not necessarily better if it not properly matches as a total system. Thanks |
| I'm installing r56 brembo front brakes to my r53 next week, ordered my gooridge r56 hoses via lohen. Whats the clearance between R105 to the calliper using 5mm spacers? Do I need to install extended wheel bolts to be safe or can i stay with the original bolts? thanks in advance |
| Me again. ![]() The R105 wheels will fit with just a 2mm spacer (but 3mm is better). No problems to date with the standard bolts using either of these, but I am using the later 14mm stud wheel bearings. My car has just failed its MOT though due to excessive corrosion of one of the front discs. While this explains the brake vibration, it's a bit irritating. Anyone else had problems? |
| Tags: jcw brakes |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/wheels-tyres-brakes/160329-john-cooper-works-twin-pot-16-brakes.html | ||||
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Mar 23rd, 2009 01:52 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Mar 23rd, 2009 01:31 PM | |
| Mini Cooper Modification Information -- SooperCooperInfo.com | This thread | Refback | Mar 20th, 2009 02:55 PM | |
| MINI COOPER :: North American Motoring - 09 JCW Brake Rotors | This thread | Refback | Mar 1st, 2009 07:29 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Feb 13th, 2009 08:10 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Feb 13th, 2009 03:25 PM | |
| Mini Cooper Brakes Information -- SooperCooperInfo.com | This thread | Refback | Feb 13th, 2009 01:33 PM | |
| MINI COOPER :: North American Motoring - Spotted: R53 w/JCW BBK | This thread | Refback | Feb 1st, 2009 04:49 PM | |
| Mini Cooper DIY Information - SooperCooperInfo.com | This thread | Refback | Jan 12th, 2009 04:21 PM | |
| MINI COOPER :: North American Motoring - Difference between R53 and R56 braking systems? | This thread | Refback | Dec 25th, 2008 05:32 PM | |
| 4 pot brakes, are they worth it? | carln | Wheels, Tyres & Brakes | 29 | Mar 21st, 2008 02:35 AM |
| 16" Alloys With JCW Brakes? | MiniOnd | Wheels, Tyres & Brakes | 26 | Mar 8th, 2007 04:01 PM |
| 16" and JCW Brakes | hyprblu | First Generation Works | 5 | Oct 5th, 2006 05:47 PM |
| What "red" matches the JCW brakes! | rentagas | First Generation MINI Tuning | 0 | May 6th, 2005 06:47 PM |
| Brembo 4-pot big brakes | Bad Manners | First Generation MINI Tuning | 11 | Aug 20th, 2003 02:00 PM |
