JCW Twin-pot 16" Brakes - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
LinkBack (10) Thread Tools Rate Thread
  6 links from elsewhere to this Post. Click to view. #16 (permalink)
Old Aug 2nd, 2008, 11:24 PM
FON's Avatar
FON
Send a message via MSN to FON
Local Time: 05:33 PM
Portugal Male View FON's Classified Ads
Quote: Originally Posted by James@fomsport (original)
there 4 pot opposing calipers hence why you see 2 positions on the out side if there were 4 pistons on the outside they would be 8 pots,
as unlike the stock claw type where the piston is on the inside and uses the force to pull the caliper in and make it a 2 pot you can get 4 pots of this type where there a 2 pistons on the inside
Do you have prices yet?
  #17 (permalink)
Old Aug 3rd, 2008, 05:07 PM
James@fomsport's Avatar
Scotland Male View James@fomsport's Classified Ads
i wont be supplying as theres no profit for me in jcw parts modnmini are supplying these
  #18 (permalink)
Old Aug 15th, 2008, 08:11 PM
Mike Edwards's Avatar
Local Time: 04:33 PM
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Mike Edwards's Classified Ads
Just been quoted £1400 fitted (inc VAT) for the Works 4-pots which includes a new set of rear disks, pads and calipers too (slotted disks front and rear).
  #19 (permalink)
Old Aug 16th, 2008, 09:54 AM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
Thats a hell of a lot for labour when I've been quoted about £850 for the parts Mike
  #20 (permalink)
Old Aug 16th, 2008, 10:19 PM
That was based on a parts price of £1k inc VAT.
  #21 (permalink)
Old Aug 21st, 2008, 05:51 PM
Finally ordered today and should be here early next week.
£799...
  #22 (permalink)
Old Aug 22nd, 2008, 09:56 AM
Rakey's Avatar
£799...
When you planning on fitting them Mike?
  #23 (permalink)
Old Aug 22nd, 2008, 05:19 PM
I'll do a test fitting of a front caliper (weather permitting) one evening during the week to check the wheel clearance, then fit it all properly at the weekend (subject the wheel clearance and/or having the right size wheel shim).
I plan to take pictures and do a write up* in stages.
*So people can understand how inept I am...
  #24 (permalink)
Old Aug 27th, 2008, 06:30 PM
Sports Brake Retrofit Kit.
The kit arrived today. Part number: 34 11 0 432 802
This contains:
2x Front 4-pot Brembo calipers and pads. Part number: 34 10 6 786 794
2x Rear single pot calipers and pads. Part number: 34 20 6 784 387
2x Front slotted and drilled ventilated disks. Part number: 34 11 6 784 371
2x Rear disks. Part number: 34 21 6 784 389
1x Front pad wear sensor.
1x Rear pad wear sensor.
1x Clip for pad wear sensor. Part number 34 11 0 432 802
Fitting instructions
Label
Pictures:
ID:	149872   Click image for larger version
ID:	149873   Click image for larger version
ID:	149874   Click image for larger version
ID:	149875   Click image for larger version
The Following 2 Users Say Thank You to Mike Edwards For This Useful Post:
  #25 (permalink)
Old Aug 27th, 2008, 06:33 PM
For entertainment value, here is a comparison of the new front and rear disks to the original R53 front disk* that's been sat in a corner of the garage for the last 3 years...
*still serviceable - and free to collector along with the calipers and pads.
  #26 (permalink)
Old Aug 27th, 2008, 06:47 PM
In tomorrow's installment, test fitting a front caliper to see if R91 Bullets, R95 JCW Spider Spokes, or R105 JCW Double Spokes will fit without spacers...
  #27 (permalink)
Old Aug 27th, 2008, 09:10 PM
Benny No.1's Avatar
Boosted
Send a message via MSN to Benny No.1 Send a message via Skype™ to Benny No.1
England Male View Benny No.1's Astro Black & White 2nd Gen MINI Cooper S Profile View Benny No.1's Classified Ads
This contains:
Label
I wonder how much it would be to just upgrade the front axles? It looks like all you would need is brembo calipers, dics and wear sensors. How much would those three parts be?
Mary MkII | R56 Cooper S | Performance Torque'd 230bhp & 260lb/ft
H&R Springs | Forge Resonator Delete Hose | Alta CAI | JCW Turbo Inlet Hose
  #28 (permalink)
Old Aug 27th, 2008, 11:20 PM
You could, but consider that the new rear brakes are larger diameter than the old front brakes.
Might make for "interesting" braking...
  #29 (permalink)
Old Aug 28th, 2008, 04:16 AM
Gman57's Avatar
Local Time: 11:33 AM
Mike are you fitting these on a R53? If so I'll be waiting for your write up as I would add these to my GP.
GP #1118
WC50 #401
  #30 (permalink)
Old Aug 28th, 2008, 06:56 AM
Benny No.1's Avatar
Boosted
I understand what your saying Mike, but most if not all BBK's out there are front only. The GTT Porsche big brake kit doesn't make any changes to the rear brake set up and those stoppers are immense!
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/wheels-tyres-brakes/160329-john-cooper-works-twin-pot-16-brakes.html
Posted By For Type Date
MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? This thread Refback Mar 23rd, 2009 02:52 PM
MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? This thread Refback Mar 23rd, 2009 02:31 PM
Mini Cooper Modification Information -- SooperCooperInfo.com This thread Refback Mar 20th, 2009 03:55 PM
MINI COOPER :: North American Motoring - 09 JCW Brake Rotors This thread Refback Mar 1st, 2009 08:29 PM
MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? This thread Refback Feb 13th, 2009 09:10 PM
MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? This thread Refback Feb 13th, 2009 04:25 PM
Mini Cooper Brakes Information -- SooperCooperInfo.com This thread Refback Feb 13th, 2009 02:33 PM
MINI COOPER :: North American Motoring - Spotted: R53 w/JCW BBK This thread Refback Feb 1st, 2009 05:49 PM
Mini Cooper DIY  Information - SooperCooperInfo.com This thread Refback Jan 12th, 2009 05:21 PM
MINI COOPER :: North American Motoring - Difference between R53 and R56 braking systems? This thread Refback Dec 25th, 2008 06:32 PM
4 pot brakes, are they worth it? carln Wheels, Tyres & Brakes 29 Mar 21st, 2008 03:35 AM
16" Alloys With JCW Brakes? MiniOnd Wheels, Tyres & Brakes 26 Mar 8th, 2007 05:01 PM
16" and JCW Brakes hyprblu First Generation Works 5 Oct 5th, 2006 06:47 PM
What "red" matches the JCW brakes! rentagas First Generation MINI Tuning 0 May 6th, 2005 07:47 PM
Brembo 4-pot big brakes Bad Manners First Generation MINI Tuning 11 Aug 20th, 2003 03:00 PM
