Steel Wheel Problems - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Nov 7th, 2008, 04:51 PM
mgwatson's Avatar
Local Time: 01:45 AM
Canada Male
DIY Steel Wheel Problems
Hey guys,
I recently installed a set of 185/65/15 General Altimax Arctic tires onto a set of 15" x 6" (4/100) steel wheels. They were balanced and mounted by Canadian Tire. At ~80-100km/hr im getting an ever so slight vibration in my steering wheel. Ive taken the car back to them 3 times now for re-balancing and they even tried rotating the fronts to the back and still, the vibration is there. Im just wondering if I'm being too nit-picky with the ride? Should there be a slight vibration in the steering wheel because of the studs? Any feedback would be greatly appreciated
Old Nov 7th, 2008, 05:42 PM
MINIAC's Avatar
Canned
Local Time: 12:45 AM
If the wheels don't have a centerbore of 56.1mm, where they mounted with hubcentric rings?
Old Nov 7th, 2008, 05:46 PM
mgwatson's Avatar
Canada Male
I have no idea what the diameter of the hub hole is, but no they were not mounted with the rings, and i do know that there is ~3-4mm gap between the hub and the rim hole all the way around
Old Nov 7th, 2008, 05:53 PM
MINIAC's Avatar
Canned
You need to get hubcentric rings
Old Nov 7th, 2008, 05:56 PM
mgwatson's Avatar
Canada Male
really hey? i didnt know that they made THAT big of a difference. Why dont other cars need em for their winters, just curious?
Old Nov 8th, 2008, 08:37 AM
mgwatson's Avatar
Canada Male
Does anyone know if hubcentric rings will work for steelies? pleeeeeease help me
cheers!
Old Nov 8th, 2008, 01:53 PM
cristo's Avatar
BLIKSEM (my brg/brg mc)
Local Time: 03:45 AM
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Do they even make hubcentric rings for steel wheels?
Old Nov 8th, 2008, 09:59 PM
MINIAC's Avatar
Canned
Why would wheel composition have anything to do with whether hubcentric rings are available or would work?
You also posted this in another thread ...
Quote: Originally Posted by mgwatson (original)
Hey guys. I recently just bolted on a new set of Winters on a 15" x 6" set of steel wheels. My question was regarding the safety of using the stock tapered bolts (from the alloy wheels) to bolt on the steelies with. The steel wheels are "multi-fit" and therefore have a slight taper to the mounting holes, however the lug bolts dont sink nearly as much into the steelies as they did into the alloys.
Attachment 152012 Attachment 152013
Any thoughts? Thanks
I don't know if you need different wheel bolts, but others running wheels with larger than stock centerbores without hubcentric rings have reported steering wheel vibration at higher speeds.
Old Nov 9th, 2008, 12:22 AM
mgwatson's Avatar
Canada Male
hmmm, i really have no idea what to do then . Anyone know where i can get a set of steel wheels that would sit flush on my hubs without hubcentric rings?
Old Nov 9th, 2008, 03:55 PM
MINIAC's Avatar
Canned
Have you tried getting hubcentric rings?
Old Nov 9th, 2008, 08:38 PM
mgwatson's Avatar
Canada Male
not yet. its because they would be like $45 and if i spent that on something that didnt work id be choked. I just wanna make sure that there are people out there that have had success with the rings on steelies before i do it.
MINIs with wheel trim/steel wheels. neston4nomads Wheels, Tyres & Brakes 6 May 21st, 2008 06:14 AM
Alloy wheel problems Creepy coupe General Discussion 2 Jun 3rd, 2005 01:09 PM
Steering wheel problems 40YRSLT First Generation Interior & Ice 2 Aug 16th, 2004 06:15 PM
Did someone try an steel my wheel???? Mini Lou General Discussion 9 Aug 1st, 2004 11:09 PM
Help me sort my aftermarket wheel problems... paulmon Wheels, Tyres & Brakes 12 Apr 18th, 2003 01:48 AM
