Feedback on FSD Shocks and Non RFT's - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Mar 5th, 2009, 10:54 PM
Local Time: 11:57 PM
Australia View bassetm1's Classified Ads
Here is an interesting observation which I'm not sure is shared by many others. A while back I fitted Koni FSD shocks to my MCS (2005) while still having the runflats on. Car was transformed. Read my old post on this. Last week I scored a scew in my rear runflat so I replaced all the tyres with new non runflats. 215/40/17 Bridgestone RE001. Now you would think this would be the ideal setup to stop my Mini destroying itself over bumps but since fitting these new hoops I have returned to the ride quality pre FSD, ie standard hard as crap ride quality. Now before anyone starts ranting about 40 series tyres, the difference is so small relative to the 205/45, surley not enough to make them harder than runflats? My only other thought was maybe the FSD shocks are behaving differently with the different tyres???? Not what I expected really. Any comments?
Old Mar 15th, 2009, 12:17 AM
Local Time: 02:57 PM
Ireland
Having read every review going on the site I recall that the fsds can be sensitive to tyre pressure. Most recently in his excellent long term review on this forum Neurobeaker specifically pointed out;
One thing I've found is that the ride quality is better when you keep your tyre pressures topped up properly, if the pressure drops then you don't hit bumps with enough force to allow the shock to do its special thing and travel - consequently, your ride quality worsens (becomes more harsh).
Might be worth checking the tyre pressures and experimenting with different values?
Old Mar 18th, 2009, 02:27 AM
I did have a play with the tyre pressures for exactly the reason you mention. I tried 42PSI, hard ride becomes harder. Then I tried 30PSI, harder ride becomes slightly less hard. I am all out of ideas now and have decided you can't make a silk purse out of pigs ear (I think thats how it goes), the mini wasn't made for comfort and will wear the tyres out at track days. Its a shame really because the FSD shocks with the runflats was much nicer and ultimately quicker on real roads because of its extra compliance.
Old Mar 18th, 2009, 11:46 AM
Local Time: 01:57 PM
View jayxx83's Classified Ads
Try 34 psi front and 32psi rear. Have this on mine with 205/40/18 and it handles really well and ride is not too bad. I have standard shockers with Eibach springs.
Old Mar 19th, 2009, 08:46 AM
Thanks, I'll try these pressures.
Old Mar 19th, 2009, 05:41 PM
any joy with this?? has it made a difference for you?
Old Mar 19th, 2009, 06:02 PM
NeuroBeaker's Avatar
PowerSteeringPumpActivist
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile
I'm interested to find out if you found a setup that worked for you - as, based on my experiences with tyre pressure, I would have thought good tyre pressures would have sorted it out.
On the issue of tyres... runflat tyres have more 'substance' to them - so presumably they'd be heavier. Could this account for some of the differences you're feeling? I would think a lighter tyre/wheel combination would move more in response to bumps, but overall I think many have previously found a more comfortable ride on conventional tyres.
It is a puzzling one...
All the best,
Andrew.
NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE).
Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix]
KONI FSD Shocks -- Installation??? omaher First Generation MINI Suspension 2 Nov 13th, 2012 08:16 PM
Koni FSD shocks tnoy66 First Generation MINI Suspension 31 Jun 9th, 2008 12:28 PM
What springs for Koni FSD shocks ? MacFever First Generation MINI Suspension 1 Nov 1st, 2005 08:03 AM
