| Snap ![]() Both my rears are staining on the rims ![]() I'm due into the dealer in just over a weeks time and have already told them there is a problem ![]() I've been told there is a known problem and I'm sure there must be other threads about them ![]() I had a Mazda before my Clubbie and in 3yrs I had 3 sets due to corrosion ![]() I say it's worth trying to get new from the dealer or even ask MINI as it's only just out of warranty and must have been there before it expired ![]() Good luck |
| There is a known problem on these but the East european car washes will definitely not have helped. If you had the slightest tiniest stop chip and they stuck their acid wheel cleaner on it it will have probably worked it's way in the rim and finally bubbled. NEVER use the car washes of that type. Always ready for a MINI adventure! |
| Those hand wash places can use very strong acid for the wheel cleaner, great for quickly getting them looking good but repeated use will attack the lacquer. Once the lacquer is penetrated alloy can corrode very quickly, particularly if road salt gets in there too. That said, some wheels are just poorly finished and thin/chipped patches of lacquer will allow corrosion to set in. TBH, I'd say three years isn't too bad for a set of alloys to last before any corrosion is seen, but that would very much depend on the mileage and driving conditions... |
| Thanks. I still think it's strange it's only on one wheel though. The other 3 are fine. I can see that if an alloy is chipped then corrosion can set in but on this one wheel there are quite a few patches starting. As my Mini has done less than 20000 I do think it's pretty poor that the alloys haven't lasted longer than that. |
| This is a common problem with two piece wheels. Take a look at any Porsche that is more than 2 or 3 years old and has two piece wheels and you are likely to see the same problem. |
| I used to have the JCW 18 inch polish alloys (sorry don't know the proper name of them) and had exact same problem. Both front wheels were a mess, i managed to get bmw to give me 2 brand new wheels for nothing. But within a year or so 1 of my back ones started to go the same way, I managed to replace it for a cheap price rather than have the bother of getting it refurbished (as I got told as they were polished alloys they would need to be sent away to be done ) But for that reason and hassle alone I would never get those wheels again even though I think they are the most stunning wheels mini has they call me mellow yellow! |
| i'm really unsure, you would need to wait on some clever person on here (not me, me no clever) answering. But from what I had I found that the protective seal had been broken somewhere for water to get in and basically just damaged it underneath. My friend has these 17" web spokes on her cooper S and the "polished" part of these has started to do exactly the same thing ![]() so i'm really unsure if there actually is anything you can do apart from refurb? hopefully a clever person will answer you better than I can they call me mellow yellow! |
| I had both my rear wheels replace a couple of weeks ago and now just noticed the fronts have a few small marks starting round the small screws ![]() As far as I'm concerned this will always be a warranty claim just make sure you have no curbing as that will be a let out of a claim |
| Unfortunatly ours are kerbed and corroded so no chance of a claim under warranty. Someone suggested that a bit of a rub down with wet and dry would help?? Does the corrosion affect the strength and structure of the wheel of just the look of the top surface? Benbow |
| 17" web spoke alloy repair/replacement | stefanr | Wheels, Tyres & Brakes | 7 | Sep 6th, 2008 02:00 PM |
| Kerbed Web Spoke!!!! | Pamster | Wheels, Tyres & Brakes | 1 | Jan 9th, 2007 07:51 AM |
| web spoke or r90 cross-spoke comp? | wigman15 | Wheels, Tyres & Brakes | 2 | Oct 12th, 2006 11:55 AM |
| Web Spoke ! ! ! | DamoSXI | Wheels, Tyres & Brakes | 5 | Jun 16th, 2006 02:59 PM |
| 17" Web-Spoke Alloy Wheel | Andromcs | Wheels, Tyres & Brakes | 13 | Nov 19th, 2004 09:32 PM |
