rear tyre rubbing - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Mar 31st, 2009, 12:41 PM
Local Time: 05:32 PM
United Kingdom Male View Proview1122's Solid Black & Body Color 1st Gen MINI Cooper S Profile
DIY rear tyre rubbing
Hi
I have just bought a mcs jcw 2004 and its fantastic but only with one or two people in it as soon as three or four people are in it the rear tyres rub on the little plastic joining strip that fastens two bits of the wheel arch together it’s also got two little metal clips on it, this happens when going over a bump or going round a corner it’s got standard suspension but after market 17" wheels as follows
Brayton Flame sport wheels
Stamped on the inside of the spokes
7j X 17H2
ET 42
50 70 17
Tyres
Bridgestone Portenza
215 40 17 87W run flats
Help what can I do to solve this issue because I don’t want a two seater
Old Mar 31st, 2009, 03:14 PM
MINIAC's Avatar
Canned
Local Time: 09:32 AM
I suspect that the previous owner fitted lowering springs.
Can you remove the plastic strip?
Old Mar 31st, 2009, 04:14 PM
Countdown's Avatar
surprised its rubbing with those wheels specs.
Options in order of preference for me:
1. See if you can remove/grind down the clips thats fouling the tyre?
2. Smaller tyre, perhaps less width so maybe 205/45 (which is standard on MINI 17" rims). 205/40 I suspect would defo clear it if just catching the tyre.
3. Is it lowered? by how much? raise the ride height?
4. New wheels with a higher offset, ET48 or there abouts?
Old Mar 31st, 2009, 05:24 PM
Wow thanks for swift answers
Miniac
Its got Mini stuck on the shocker so presumed standard springs but looking through the wheel spokes I see a label with RW see pic (if I can upload them) so maybe springs have been lowered please advise me.
I think the plastic strip held on with the clip is needed to join the arch to the bumper (it also sticks out from the edge a little bit so I don’t think I could get rid of it
countdown same answer to 1 and 3 205/45 seem a good Idea but if they rub again lot of money spent
don’t really want new wheel these are almost brand-new I guess previous owner never had anyone in the back
I will try to upload pics
ID:	156412   Click image for larger version
ID:	156413   Click image for larger version
Old Mar 31st, 2009, 05:37 PM
MINIAC's Avatar
Canned
Looks lowered to me ...
A 205/45-17 tire has 6.25mm more sidewall than a 215/40-17. It will stick out 5mm less than the current tires but I'm not sure they won't rub.
Old Mar 31st, 2009, 10:04 PM
sorry I just looked again and the tyres ar not 40 profile they are 45 does that change things
7j X 17H2
ET 42
50 70 17
Tyres
215 45 17 87W run flat
sorry about that
Old Mar 31st, 2009, 10:11 PM
MINIAC's Avatar
Canned
Yes ... running 215/40-17 instead of 215/45-17 tires will give you 10.75mm more clearance.
If you want run flats you'll have to go with 205/45-17 Bridgestone Potenza RE050A RFT.
Old Mar 31st, 2009, 11:21 PM
Countdown's Avatar
Lowered on Eibach Springs (by approx 35mm).
Old Apr 1st, 2009, 03:47 PM
Yes I agree with estimate! And you think they are Eibach Springs I did not realise it had been lowered!
I did a very scientific test I parked next to a standard 1st gen mini (assume ride height is the same) put two fingers between rear tyre and wheel arch I can only get one finger between my rear tyre and arch, measure finger width = approximately 30mm
So
car is lowered approx 30 - 35mm
has
7j X 17H2
ET 42
and tyres are
What shall I do go for the 205 / 45 / 17 bridgestones would this give the clearence I need or remove the little flap of plastic and the clips as I have read someone doing on this forum would this work? It would be a lot cheaper although would I have probs with arch bumper lining up / vibrating.
BTW what does the flap do?
TIA
Tags: , , , ,
Rear Tyre Wear BENJ Wheels, Tyres & Brakes 2 Nov 26th, 2007 05:01 PM
cooper s rear wheel rubbing? rapunzal Maintenance & MINI Care 0 Mar 26th, 2006 01:35 PM
Rear tyre pressure goes up - why? n00b Wheels, Tyres & Brakes 3 Apr 10th, 2005 09:00 PM
uneven rear tyre wear? TommycooperS First Generation Faults & Fixes 2 Apr 7th, 2005 06:47 PM
Rear Rubbing w Eibach springs for MCS. disdis First Generation MINI Suspension 2 Jun 19th, 2003 09:40 PM
