| I'd avoid any sort of DIY kit, the parts required are easily available from any place like Halfords. Here's two useful guides from other forums: Refurbing & Spraying Alloy Wheels... - Detailing World Wheel Refurb - Detailing World Just be aware that it's very time consuming! If you do go ahead, I'm sure plenty of forum readers would like to see pics of your own experience |
| I just did a wheel on my Focus ST and I did the following: 1 - Cleaned Wheel with white spirit 2 - Used Evo-stik Hard & Fast Metal Epoxy Putty(halfords) to fill the scrapes (wish I hadn't put so much on as it takes some sanding down, even with 200grit). 3 - Sprayed 3 coates of Hi-Build grey primer (leaving 15mins between coats then left for 24 hours) 4 - Sanded using 800/12000 grit Wet and Dry (halfords assorted pack) and cleaned again with white spirit. Tip: Take the extra time at this stage as for best results the primer needs to be as smooth as glass! 5 - Sprayed 3 coates of MG Rover Sparkle silver (was a good match for ST wheel). I left the paint 24 hours but then didn't sand this down (this gives depth to the metallic paint according to the paint can...I think it did) 6 - Sprayed 4-5 coats of lacquer and 1600 grit wet sanded and finished with a polish with T-Cut rapid scratch remover to remove any laucqer run/overspray. There's probably a few techniques, but that's the way I did it and I'm happy with the result! |
| Tags: alloy, diy, repair, wheel |
| alloy Wheel repair | paul04 | Maintenance & MINI Care | 21 | Mar 6th, 2007 04:15 PM |
| Alloy wheel repair | Birdog | Wheels, Tyres & Brakes | 3 | Jun 13th, 2006 11:43 PM |
| DIY Alloy Wheel Repairs | Red Dwarf | Wheels, Tyres & Brakes | 0 | Oct 27th, 2004 05:45 PM |
| DIY Repair Alloy Scuff Marks | Kinster | First Generation Faults & Fixes | 7 | Aug 26th, 2003 04:35 PM |
| Alloy Wheel Repair. | Austin | Wheels, Tyres & Brakes | 3 | Dec 10th, 2002 08:46 PM |
