| Re: Re: Drag radials I've cranked my S up to 115 or so in 5th. 5th really doesn't start pulling until 80 mph or so. 6th gear under a 100 mph is like throwing an anchor out and dragging it. I haven't run a 1/4 on a track, but if you are into 5th gear something is wrong. Missing my buddies Dan, Ed, and Diane but glad I have three angel buddies , And on a quest to Right Secco's Wrongs |
| Hi suprchrgdmini..... The idea of using a 15" wheel is correct for dragracing not because of the rolling radius although it does gear the car down a bit...No the reason is that the taller tire will be filled with a small amount of air so what happens is the tire will actualy wrinkle a little and give you superior traction. I would go to Thompson race tires,Nitto tires or BFG tires check out the info and make a informed decission. Good luck peter Red MCS, Cobra Technology seats,Carbon bottle fire fighter system(not NOS). Stack Gauge panel. Supertrapp exhaust system and more to come(rollcage,headers,Etc.)Mini rules Long Beach |
| Tire Size Comparator This is a handy tire size comparator: http://www.miata.net/garage/tirecalc.html Your 215/35-18 are already a little shorter than the stockers. 225/50-15 would keep your current gearing the same. http://www.tirerack.com/tires/Sizes....FA+Drag+Radial |
| 356BHP 12.162 @119.02 on BFG Drag Radials | Paul@1320 | First Generation MINI Tuning | 9 | Sep 10th, 2007 01:30 PM |
| did some drag racing....... | MiniMexico | First Generation MINI Tuning | 1 | Jul 18th, 2007 04:53 PM |
| A.I.R. Drag results | malliemcg | Australia | 7 | Jan 30th, 2005 12:44 AM |
| Drag help | giantmidget | MINI in Motorsport | 4 | Jul 30th, 2003 09:58 PM |
