R56 Brake Pad Sensor - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Dec 5th, 2009, 04:07 PM
danb's Avatar
Local Time: 10:54 PM
United Kingdom Male View danb's Astro Black & Body Color 2nd Gen MINI Cooper S Profile View danb's Classified Ads
After a warning message came up on my Nav on Friday telling me that my front brake pads needed changing (the final warning, not xxx miles), I have just swapped my OEM pads for Mintex ones.
I've replaced my pad sensor with a new one from BMW, but the warning is still coming up after over an hour. Previously I had the warning in two places; under the service warning menu, and under the error check menu. The error check menu is no longer showing the error, but the service warnings is still showing front brake pads due.
Any ideas?
Old Dec 6th, 2009, 02:58 PM
danb's Avatar
Finally found the answer... credit goes to Humph. I'm not sure why I didn't find that on my first search, but nevermind
MAKE SURE DRIVERS DOOR IS CLOSED
Insert Key
Do not press clutch / brake
Press Start button
Wait until the Car / revelant Service symbol disappears on the Rev counter display
Immediately after the symbol goes out - Press and hold Both buttons on the Rev Counter
Continue to hold - the system Will run a dash light check
Continue to hold
Display will then show VIN / Menu, - continue to hold through this until the time Reappears on the display.
Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button)
After another second or 2 the display will show the Front Brake Symbol You Are Now in the Service Menu
Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Rear Brakes
To Reset the warning indicator light - Press & Hold the BC Button at the revelant symbol until RESET appears - then press and hold again until the process is complete.
Turn Off and On the Ignition again - Warning should now have gone!
Old Jan 11th, 2010, 06:04 PM
Sorry if this is a silly question, does this process reset the mileage counter, just about to change my rear pads. Vehicle is a 2008 Cooper S, the Turbo one
George
Brake pad wear sensor R56 Tobes Maintenance & MINI Care 4 Dec 9th, 2008 04:29 PM
Brake pad warning sensor. Mat-CooperS First Generation Faults & Fixes 5 Aug 22nd, 2007 08:22 PM
Brake pad sensor dazzpowder Maintenance & MINI Care 2 Feb 7th, 2007 02:54 PM
Brake pad sensor at 20K xnetco Wheels, Tyres & Brakes 11 Feb 2nd, 2006 08:09 AM
Brake pad sensor light Fabio First Generation Faults & Fixes 19 May 12th, 2005 05:39 PM
