Changing from run flats to standard tyres on Mini Cooper S - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 14th, 2010, 09:22 AM
Local Time: 03:54 AM
Hi everyone,
I bought a 2003 registered Mini about 4 months ago (my first!) and I love the car. However, it came with Pirelli Eufori@ 205/45/17 run flats and I've just had a puncture....I naively didn't realise these can't be repaired! I've seen a lot of discussion around the pros and cons of runflats and I'm leaning towards changing all four tyres to standard tyres.
So the question is:
Could anyone recommend standard tyres (mid to high class) for the Cooper S? I'm not particularly attached to any brand. I tried a little to find out what standard tyres are being fitted to new (normal) Minis for a bit of guidance but no luck - so if anyone has recently bought a mini and can shed some light that would be helpful too?
Thanks a lot people!
Old Jan 14th, 2010, 09:49 AM
MACKIT's Avatar
Is over to the dark side
Local Time: 04:54 AM
United Kingdom Male View MACKIT's Classified Ads
I would take a look through the wheels and tyres section. There is a lot of debate on this subject and a particular tyre may jump out from reading through other's feedback in this section of the forum.
Old Jan 14th, 2010, 10:12 AM
Thanks MACKIT. I'm new on here and thought I had a good look round but clearly not as I failed to check out the whole tyre thread!! Going there now to have a look.
Old Jan 14th, 2010, 10:48 AM
MINIcharged's Avatar
Have a look at this thread I started a few weeks back.
It's very similar to you question, I was hoping to get a few more tyre reviews on there but nevermind.
Old Jan 14th, 2010, 05:03 PM
cooper1019's Avatar
cooper1019
United Kingdom Male View cooper1019's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile View cooper1019's Classified Ads
runflats
Quote: Originally Posted by miniloving (original)
Hi everyone,
So the question is:
the runflats can be repaired just like a normal tyre,i have had 2 punctures and had them fixed no problem,unless the sidewall is damaged,and remember that the suspension on the cooper S has been set up for runflats,so when you change to ordinary tyres you change the set up,and you will need a foam filler incase of a puncture,when i got a puncture in mine i just carried on going a further 170 miles with no problem,so a brilliant idea imo.
Old Jan 14th, 2010, 05:14 PM
jlove's Avatar
3 JWL
England Male View jlove's Laser Blue & White 2nd Gen MINI John Cooper Works Profile View jlove's Classified Ads
I've just posted on http://www.mini2.com/forum/wheels-ty...est-price.html FYI.
Tags: , , ,
Replacing run flat tyres with standard tyres? Bells Wheels, Tyres & Brakes 33 Oct 5th, 2010 08:46 PM
Changing from runflats to non run flats. MrMackem Wheels, Tyres & Brakes 16 Feb 18th, 2009 06:33 PM
Non-run Flats on standard rims??? stoppie Wheels, Tyres & Brakes 2 Jan 15th, 2008 01:26 PM
Is there a noticable ride difference between run flats and standard tyres? dazotron Wheels, Tyres & Brakes 7 Jan 1st, 2007 01:52 PM
Changing run-flats poddy Wheels, Tyres & Brakes 5 Aug 23rd, 2006 09:01 PM
