| Tyre wear on run flats I've just noticed that both my front tyres (Dunlop 16")are going to have to be replaced v.shortly. I've only done 7000 miles! Anyone else got poor mileage out of their tyres. I don't fancy replacing them every 7000 miles or so. The rears are fine and hardly wornand its not as if I've been ragging it everywhere. Could my tracking be out? Another point I suppose is how much are replacement run flats? Any help or opinions will be much appreciated. Brad. |
| R50 investigated the prices for these tires here . I will soon do the same in this area. I am looking for 17" run flats, but will ask about the 16" ones as well and post the results here. Does your car have/had the "pull to left " syndrome? If so, that will explain for the early wear... and your dealer should do something about it... |
| Further to HarryIndyBlue's comments, have your front wheel alignment checked and tires rotated. It should help you get more mileage out of the present set. 2010 Toyota Prius Technology Pkg. 2009 Brabus Smart Coupe 2009 Honda FiT Sports Pkg. 2005 MB C55AMG 2005 V-Star 1100 Custom 2007 Honda 250 Reflex |
| On a re-think, I suspect that 4 seasons out of my Goodyears will not be possible. The fronts lost 5mm this season, the rears lost 2mm. That means when swapped the fronts and rears should both be down to 3mm after next spring & summer, assuming I drive as hard as I did this year. That will *hopefully* give me a third season on them, perhaps assuming that I rotate the rears to the front partway through. So it looks like I'll probably get a total of 18000 miles or 29000km out of them. If your 280 rated Dunlops are bald on the front at 7000 miles then I'd wonder about underinflation, especially if it is worse at both edges. Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| Thanks for all the replys people. The wear seems to be fairly even over both the fronts, The tread is down to about 2mm. The car is due for its first service soon so I'll get the dealer to check the tracking and alignment etc as I'm not too pleased about the wear. To be be fair this is the only complaint I can level at the car in a year of ownership, but I'm still a bit miffed. |
| Tyre sealant system rather than run flats | Westy | Wheels, Tyres & Brakes | 6 | Apr 8th, 2006 12:45 PM |
| Run Flat Tyre Wear | NettyD | Wheels, Tyres & Brakes | 5 | May 9th, 2005 06:31 PM |
| Tyre foam - non-run flats | wildchild jules | Wheels, Tyres & Brakes | 2 | Jan 26th, 2005 01:59 PM |
| Replacing run flats with non run flats? | minifrog | Wheels, Tyres & Brakes | 2 | Oct 24th, 2003 04:14 AM |
| Buy New Run Flats or a Wheel & Tyre Package | jon.od | Wheels, Tyres & Brakes | 3 | May 27th, 2003 02:55 AM |
