| Re: Found out the hard way...... The problem can't be because it was a Cooper S, can it? Those wheels would be a problem on any MINI, right? + 2002 MINI Cooper S - Dark Silver / White roof, Sport, Premium, Lapis blue leather + 1965 Mini Traveller - Tartan Red / White roof, 1275, Cooper S discs, fully restored/renewed |
| This is odd I've got 15" steel wheels that were ordered from tirerack on my Cooper. I was going to post the width of the wheel by looking it up on tirerack, but now I no longer see steel wheels as an option on their website for a MINI. hmmm... Anyway, like I've said before, the first set of 15" steelies tirerack sent didn't clear the front brakes. The second set did. |
| Dom, the 17's are 7 inche's wide, but they are also 2 inches bigger in diamiter. The lower Control arm has a bolt the sticks out and it caught the inside of the barrel of the wheel. Since its 2 inches smaller, its that much closer to the arm. I thought the e-brake was stuck on . A more narrow wheel might fit, but TC from Discount tire said the info he got was from MINI themselves saying that no 15 will fit--go figure. I am now in the look out for a lighter 16 x 6.5 inch wheel--probably wont find one very soon--I might just get some stock Cooper S wheels--but I'd like something lighter and the ones from AKtire dont seem to be moving along very smoothly and I wouldn't see them till at least december.One reason I was going with the 15x7's was I had an unlimitied supply of R compund tires I could use . Thems the brakes I guess.Daniel Cooper S: Now new and improved with Helix short shifter, Ghetto K&N HAI, Rota Circuit 8's w/ T1'S Proxies/Kosei K1 racing wheels with Falken Azenis(for Auto-X/Trackday), and H-sport springs. UUC rear sway waiting to install |
| Snid, I've seen at least one post about the steel wheels from the Tire Rack not fitting an S. I can't remember if they were 15" or 16". The Tire Rack had listed both, but they are both gone from their website. CSDan, I know a lot of people who have been buying the 15" 7 Holes for winter use on their S, but I don't know anyone who's actually put them on. It's strange what MINI said about NO 15" fitting.... |
| 15x7 not fitting! I bought a set of 15x6 csa(australian brand) alloys that i fitted with 205/50/15 yokahama 032r tyres and had no clearance problems, 15's do fit you just need to find the right offset and width. |
| At least someone finally test fitted something before me so I don't get screwed... There are MANY variables to fitting a wheel on a car, especially when you getting them smaller in diameter. If you ever order a custom wheel, you'll see what I mean. Aside from the diameter, width, and offset, things like several different measurements in caliper clearance and how thick the hub pad is are CRUCIAL. In this case, I guess it was suspension clearance as well. But, just keep in mind with any new car, always make sure you can send them back if you don't know anyone running the identical wheel already. Thank you very much for the feedback CSDan, it is greatly appreciated. Although I haven't started my research yet, we planned on putting 15x7's or 15x8's on our FSP car. I will certainly be even more careful now. Brian - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| I have winter tire4s on 15" rims on my MCS with no problem. use this site to calculate proper offset. http://toy4two.home.mindspring.com/offset.html |
| VERY useful, thanks. While we're at it, I'll include a couple more that many of you know about: For tire calculations: http://www.miata.net/garage/tirecalc.html For various wheel weights: http://europeanspeed.com/wheelweights.htm Brian - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| Brian-- No problem, glad to help So all of you know--the offset was 38.I would think that the stock 15's would fit, but I do want to use these wheels as double duty snow/autocross wheels. So I wanted to go wider then the 5.5's plus the tire supply I had wouldn't fit a 5.5. SO--My MINI mechanic(who is my friends gf's brother inlaw(got that))came by last night and checked out what he though it was hitting. It was the ball joint. So I could try spacers but it would be at least a 10mm and it would still be close, so I am returning them and looking for some 16x6.5 wheels since it looks like the S will be reclassed next season(crossing fingures, dont really have money for LSD at the moment). So brian, if you want to dump a set of those RPO-1's, let me know .Daniel Cooper S: Now new and improved with Helix short shifter, Ghetto K&N HAI, Rota Circuit 8's w/ T1'S Proxies/Kosei K1 racing wheels with Falken Azenis(for Auto-X/Trackday), and H-sport springs. UUC rear sway waiting to install |
| Private sale- anyone else found it hard? | Gary09 | General Discussion | 3 | Jan 20th, 2007 05:40 PM |
| Fitting a chrome tailpipe trim for "Cooper" - HELP | rex28 | First Generation MINI Exterior | 8 | May 2nd, 2005 12:57 PM |
| Handling changes after fitting 18" Wheels | Bezza | Wheels, Tyres & Brakes | 10 | Apr 23rd, 2005 12:34 AM |
| Fitting 18" wheels- Spacers required? | beaufort9 | Wheels, Tyres & Brakes | 4 | Jan 12th, 2005 04:22 PM |
| 17" bullets on hard-top Cooper S. | MukiMunki | Wheels, Tyres & Brakes | 6 | Jun 8th, 2004 02:09 PM |
