Tyre pressures!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jul 27th, 2011, 01:12 PM
Local Time: 03:58 AM
England Female
England Tyre pressures!!
I've got a mini cooper & they dont have the mini run flat tyres on it, they have 18inch tyres on them. I've had the car for about a year & it's always had these tyres. But recently (past few months) the tyre pressures just keep going down really really quickly. Every week I'm having to pump them up & usually they're on as low PSI as 5! Last week I got 'eggs' in 1 of my front tyres & thus had it replaced. But even this new tyre is going down within a week & you can visibily see that its quite flat!
Does anyone have any ideas as to what this could be!? I did originally think I just needed all new tyres, although the fact that this new tyre is still going down quickly seems to suggest otherwise ?!
Old Jul 27th, 2011, 03:53 PM
Local Time: 04:58 AM
If your alloys are corroded enough, that can cause loss of pressure - I have had that before, but the appearance of the alloys will be pretty bad by the time this becomes a problem. The corrosion prevents the tyre from making an airtight seal to the rim.
If you've got the lacquer/paint on the alloys lifting/flaking off at the rim, then this could be the problem. It would explain how come a new tyre has the same problem, but I would have expected to tyre fitter to notice and mention the corrosion, if it was bad enough to do this.
Tags: , ,
Tyre Pressures RooniusMaximus Wheels, Tyres & Brakes 4 Oct 9th, 2008 11:32 AM
Tyre Pressures Chilli Harry Wheels, Tyres & Brakes 1 Aug 29th, 2008 03:45 PM
Tyre Pressures Darthbladerni Wheels, Tyres & Brakes 2 Jan 23rd, 2008 06:28 PM
215/35/18 tyre pressures? CWaldie Wheels, Tyres & Brakes 5 Feb 26th, 2006 04:21 PM
Tyre pressures robfenn Wheels, Tyres & Brakes 7 Jan 12th, 2005 06:48 PM
