Brake Sensors! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Aug 3rd, 2011, 11:27 PM
~*MiniS*~
Local Time: 04:58 AM
United Kingdom Female
Brake Sensors!
Hey!
I have a MiniS and recently I got the front brake pads and sensors changed as they were low and the sensor came on.
However the sensor light still comes on even after it been replaced and checked. I went to a mini specialist garage who checked the brakes and sensors were correct used and put in (which it was) and also put the car on the computer diagnostic to check if it only needs to be reset. They tried to rest this but it wont let them. They checked the wiring was all correct and it was.
Does anyone know what the problem could be and how to resolve it?
When I start the car, I get a a few sensors coming up;
The engine light in yellow (on the big spedometer)
The first circle on the speedometer is red (I think this is the brake-pad sensor)
The fifth circle (abs sign) shows up when starting the car on the revolution counter.
The second circle on the revolution counter is red and stays red throughout driving.
Hope you guys can help, any further questions just ask
Thanks,
Avani
Old Aug 3rd, 2011, 11:58 PM
stefanr's Avatar
CooperS
Think I read somewhere you just need to put the key in the ignition and turn to position 2 for 30 seconds without starting the engine, the light should go off and have been reset. It's not a computer reset.
Old Aug 4th, 2011, 09:35 PM
~*MiniS*~
I don't think I can change the fob into different positions, I have read this before and tried it...
Old Aug 5th, 2011, 11:59 AM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
Do you have a first or second gen mini?
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Aug 9th, 2011, 10:35 AM
~*MiniS*~
Second Generation Mini (08 Plate)
Tags: , , ,
Brake sensors bigdave645 Maintenance & MINI Care 2 Mar 30th, 2009 09:35 PM
Brake Pad Sensors neraij Wheels, Tyres & Brakes 2 Oct 28th, 2008 10:28 PM
Brake Pad Sensors Lau Wheels, Tyres & Brakes 8 Sep 6th, 2008 12:28 PM
Which AFTERMARKET brake pads will be compatible with brake sensors? wrxtomini Maintenance & MINI Care 0 Apr 22nd, 2006 03:17 PM
Brake pad sensors joeinitaly First Generation Faults & Fixes 2 Dec 13th, 2004 04:49 AM
