Changing Rear Discs, Pads & Sensor(s) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 9th, 2012, 08:35 PM
Local Time: 03:59 AM
DIY Changing Rear Discs, Pads & Sensor(s)
Hi All,
I have a Mini One D - 04. Had it 5 years next month and love it - however just lost my job and money is tight, however my rear brake discs & pads need changing, so tomorrow me and my father in law are going to grab the parts (have checked and are in stock!) and change them however I have a couple of questions...
Is there a brake pad wear sensor on each wheel or just one?
Can anyone point me in the direction of some guides/walk throughs on here or on the net? I've found a few for the front wheels but from reading some of the forums it looks like theres a bit of difference?
Also - a bit random, but we're going to change the fuel filter while we're on and I know its behind the rear driver side wheel arch, but once located how difficult is this to change?
Thanks alot in advance!
Andy
Old Jan 9th, 2012, 09:52 PM
Local Time: 04:59 AM
Hi
on the minis there are only two brake pad sensors front left and rear right
Unless you sensor has brought the light on you can get away with out changing it if you carefull. I have been told that the sensors are graduated and that's how it works out how many miles it need till pads are about to be worn out.
Have a look at these link see if there any help to you
Maintenance :: Changing REAR Brake Pads for Beginners! - North American Motoring
DIY Rear Brake Pads | R56 MINI Cooper Blog
New brake pads and a turbo thermal/heat shield>>> - North American Motoring
changing discs and pads on MCS spennyp Maintenance & MINI Care 10 Aug 4th, 2009 06:48 AM
Changing brake discs and pads jackscoopers First Generation MINI Cooper S 2 Jun 13th, 2009 11:38 AM
Changing Discs and Pads for my R56 S Roseman Wheels, Tyres & Brakes 7 Oct 18th, 2008 11:06 AM
changing pads and discs - tool needed matt21 Wheels, Tyres & Brakes 6 Jun 27th, 2008 05:53 AM
Rear discs and pads Buz999 Wheels, Tyres & Brakes 10 Jul 4th, 2007 09:15 PM
