| 18" rims will invariably be heavier than a comparable 17" rim. This will have an effect on performance, but you'll probably not notice it in an S. The main things to consider are ride quality, especially if you'll be sticking with run flat tyres. 17" RFs are expensive enough as it is, but in 18" they're a whole chunk more. Even if you stick with regular tyres, ride quality will still be compromised, and replacement rubber will still be proportionately more expensive. 18s do look more imposing (and most of the 18" JCW rims are absolutely lovely), but personally, I'd say 17s are perfectly adequate for the Clubman, and hatch. |
| Hi Both will fit on but like the guys say 18" will give you a lower profile which will make the ride a little harder but not unbearable But from 16" to 18" you will notice it big time If you do fit 18" wheels depending on the type and off set you will need steering limiters to stop you hitting the inner arch when you turn left or right Hope this helps out a little |
| As many have said, you don't really need them with oem rims and you certainly don't need them with aftermarket ones. As for 17" vs 18", just pick what you like more, the ride will be similar with good tyre and not extremely low profile (aka not 215/35 R18), 215/35 non-RF is similar to 205/45 R17 RF. The best choice is 215/40 R18, imo. Mini Cooper S (2007), 158 kW and 312 NM. |
| I'll agree with that, very little difference in ride comfort but look much better. I'd stick to 7" as you are less likely to have problems with the fit. Narrower rims give better turn in as well. ![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
| 3M Sez.."Raise the roof!" "Barn-raising party" Saturday, Jan 7th 2006 | MetalMiniMayhem | New York & New England Region | 127 | Jan 6th, 2006 11:07 PM |
| What's the furthest "Range" shown on your Trip Computer? Mines "540 miles" | waynef | General Discussion | 14 | Nov 1st, 2002 09:29 AM |
