R56 JCW brakes for R53 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 16th, 2012, 01:01 PM
Local Time: 05:00 AM
Guernsey View GuernseyGooner's Classified Ads
Hello
As title suggests, I have picked up a good deal of new front and rear calipers, pads and braided hoses for just over £500.
Obviously I know I need to get discs and I know about the modification needed on the rears for the handbrake cable. My question is if I need anything else on the attached pic? Item 13 is called a protection plate and would I need to get new brake pad sensors?
Old Jan 16th, 2012, 01:05 PM
htspike69's Avatar
Local Time: 04:00 AM
United Kingdom View htspike69's Classified Ads
Pads, wear sensors and new brake lines as the fitment is different. go for s/s braided.
With brakes go for new bits as its your life !
Old Jan 16th, 2012, 05:45 PM
I have them fitted to my car. The modification to the rear handbrake cable is a slight pain to do, but replacing the cable is even more of a pain.
The protection plate is removed and not needed.
The fronts are just a straight swap. I would also bleed the clutch after doing the brakes too.
Old Jan 16th, 2012, 08:39 PM
Thanks for that. So I just need discs and I'm good to go? Can I use the existing brake pad sensors as long as the light hasn't come on?
Old Jan 16th, 2012, 09:12 PM
I used the old sensors as the old pads hadn't worn down that far.
They can be a slight pain to remove tho.
Brakes Pre-11/06 Mon-mate Wheels, Tyres & Brakes 21 Jun 26th, 2009 05:31 PM
Where can i get jcw brakes? lucachiarelli Wheels, Tyres & Brakes 4 Aug 24th, 2007 05:40 PM
Brakes maggiepearl90 Wheels, Tyres & Brakes 4 Aug 21st, 2007 04:57 PM
Will big brakes fit? cooper7 First Generation MINI Tuning 6 Aug 12th, 2004 07:49 AM
one & Mc brakes bobnobski General Discussion 2 Feb 4th, 2004 09:33 AM
