Will it rub ?! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 25th, 2012, 07:36 PM
DanJackGrant's Avatar
Geordie with a MINI
Local Time: 05:00 AM
England Male View DanJackGrant's Classified Ads
Will it rub ?!
Hey guys
I am looking to fit a set of new alloys to my MINI Cooper. I am wanting to put a wider tyre on such as a 205/40/17 or a 215/40/17. The only thing I am worried about with the 215s is about any clearance issues ? I don't want to fit the tyres then realise they are rubbing against the inside of the arches. I am also lowering the car by 30mm
Old Jan 25th, 2012, 10:07 PM
Hi
I have 215/40/17 's on mine and they clear, but Depending on the offset of the wheel Package your going for it will depend. have a good read of the FAQ section it may help you
The offset and bore dimensions are the most important parts to take not of
MINI Cooper Forum - MINI2 Mini Cooper Forums - FAQ & DIY: MINI DIY & FAQ - ALL GENERATIONS
When you get them fitted remember to post some pictures :-)
Old Jan 26th, 2012, 09:58 AM
Geordie with a MINI
What offset are you running on ? Was thinking about a 38 ? Then even considering fitting either 3mm or 5mm spacers
