Wheel spacers - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Feb 8th, 2012, 03:48 PM
Local Time: 05:00 AM
Guernsey View GuernseyGooner's Classified Ads
Wheel spacers
Hello,
After having my R53 lowered, my R112 alloys look tucked into the arches so was thinking of filling out the gap with spacers. At the moment there is about 18mm between the tyre and the outside edge of the arch which looks visually worse up front.
Do I use the same all round or make the front track wider, say 12mm on the fronts and 5mm on the rears? Also, are they safe?
Thanks for help
Old Feb 11th, 2012, 08:24 PM
Nick007's Avatar
Local Time: 06:00 AM
Czech Republic Male
15 or 12 mm front and 5 mm rear is perfectly okay and perfectly safe if you buy some quality ones (like hubcentric H&R).
I have 15 mm front and 5 mm rear because of JCW BBK & R109 summer / R98 winter combo (spacers are needed only in the front, 15 mm for R98, 7 mm would do for R109).
Remember to have longer lugs - standard length is 28 mm, so 43 mm for 15 mm spacers or 33 mm for 5 mm spacers.
Mini Cooper S (2007), 158 kW and 312 NM.
Wheel Spacers MINIman1187 First Generation MINI Cooper S 2 Oct 26th, 2011 02:06 AM
Wheel spacers with longer (M14x1.25) Wheel bolts Maaij Wheels, Tyres & Brakes 0 Mar 31st, 2007 01:59 PM
Wheel Spacers beatbox Wheels, Tyres & Brakes 5 Jul 12th, 2005 10:41 AM
Wheel Spacers for MCS monkeynuts First Generation MINI Cooper S 0 Feb 7th, 2004 01:40 PM
wheel spacers red03miniS Wheels, Tyres & Brakes 12 Dec 11th, 2003 06:03 PM
