| 2005 cooper s chilli pack - what is correct 16" non run lat tyre size? We are considering put 16" non run flat tyres on our 2005 cooper s chilli pack car with LSD (don't know if an of the above makes a difference). I'll admit to having no clue as to what tyre size to use when buying the 16" alloys so could someone please tell me. Also, if we stick with the 17"s then what non run flat tyre size should we but? Thanks in advance |
| Hi ya Normaly on a standard 16" mini wheel 195/55/16 Normaly on a standard 17" mini wheel 205/45/17 These sizes are the same run flat or normal construction it's the circumference you are worried about Have a read of this thread very helpfull everything you will need to know about wheels and tires and also images of wheel options http://www.mini2.com/forum/faq.php?f...wheel_fitments |
| Thx very much for the info it's nice and simple for me to understand. I did read that thread but I easily get confused with tyres and rims so your advice is exactly what I wanted to know. I keep reading about the dramatic difference non run flats make but I wonder if it really is dramatic? |
| I think a plan is forming but could I ask when buying tyres is there much in it if I go Michelin/continental/Bridgestone/Goodyear? I know everyone has a preference but is there one stand out all year tyre for 16" rims? |
| Don't think there is much in it for the top brands but these magazine tyre tests are sometimes helpful: Tyre Test 2011 | Products | Auto Express Auto Express - Total Tyre Guide |
| Could I ask one more question - is there any reason not to use 205 50 17 tyres on the existing rims? The reason I ask is that on one of the tyre calculators it shows moving to 205 50 17 non run flats from 205 45 17's improves the "comfort factor" by 80% |
| Thx, I'm a little confused which way to go as a good friend suggested the 205/50 as being within limits, glad I asked ![]() Am I right in assuming more side wall make the ride softer and if I go with 215's then the tyres won't catch in the arches but I guess the steering will get heavier? |
| I can't seem to find this tyre calculator thing now but it had a factor rating for comfort and I guess I was trying to work out what is the best way of improving comforting/reducing jitter whilst staying on 17"s as this would help keep costs down. The car is standard and will remain that way and I can't seem to find a decent set of whit 16" rims hence the look at the alternative. I read a lot about the ride improving from run flats to non run flats but trying to quantify it is hard and I want to get the biggest improvement I can. |
| Tyre size for 15" cooper alloys? | ryanm8655 | Second Generation MINI Cooper | 3 | Sep 2nd, 2010 05:26 AM |
| MCS + Chilli Pack + 16" Alloys ?!?! | babelfish | Second Generation MINI Cooper S | 2 | Oct 30th, 2006 01:29 PM |
| Chilli Pack to change in 2005??? | Phrozen | General Discussion | 28 | Oct 24th, 2004 10:32 PM |
| 17" Runflats Correct Tyre Pressure | DCM | Wheels, Tyres & Brakes | 5 | Aug 12th, 2004 12:55 PM |
| Correct Cooper 15" Tyre Pressure? | lightbody | Maintenance & MINI Care | 2 | Jul 17th, 2002 03:52 PM |
