| Run Flat Tyres - flat - then reinflated!! Morning Everyone, What am I doing up at this unearthly hour!! Anyway, I recently bought an MCS - loving it. The problem lies with the tyres. This morning, I got in the car and immediately noticed a bumping sound from underneath. I pulled over and inspected the tyres (must have drove 30metres). To cut a long story short, the tyres were fine except the passenger front. The car was facing down hill (maybe this tyre was exposed to the elements more). There was a definite flat spot on the tyre (e.g. Tyre not completely round) which was making this bumping noise. I turned the car around and headed by up the hill (expecting to call the RAC as they are run flats). I told the missus and went back out to the car..... they had somehow re-inflated!!!?? and off I went to work without a hitch. At no point did the dash say I had a problem. Looking at the tyres now, there does seem to be a little less pressure in this tyre. I'm wondering if it could be something to do with tempreture (-6c last night) such as frozen rubber/sealing solution or possibly a hole has been resealed?? Any suggestions? Thanks |
| So now its a bit lighter and I can see what I'm doing..... There is no sign of a nail etc in the tyre, however there was no air either (zilch!). I presume that because the tyre had deflated, the run flat had to do a few rotations to gain its shape. I've re-inflated and it seems to be holding (for the time being) However, my dashboard sensor didn't alert me to any untoward problems. Any ideas? Ta |
| Thanks guys. Well the pressure is holding in the tyre - dash reset after reinflating. It's been standing for 8hrs - plus 10 miles of driving with no loss whatsoever. Wonder if it's self sealed. Very peculiar. |
| You probably had an intermittent leaking valve. Cold weather will reduce the pressure in the tires. The warning may not have come because the monitoring system hadn't been re-set after the last inflation. Any time you adjust the air pressure in the tires you need to let the monitoring system know. |
| Would the valve reseal by itself? Unsure if theres any "goo" in these run flats. The tempreture was low - but not to completely deflate the tyre (0psi). No alerts from the dash this am. Its most odd! Thanks for the replies. |
| The tyre pressure warning doesn't detect the actual pressure in the tyre - as far as I'm aware, it measures the number of wheel revolutions over a given distance and compares this to what it was doing previously. So if a tyre loses pressure it will have a smaller rolling circumferance and make more revolutions than if fully inflated. That's why the warning didn't trigger - the car hadn't travelled far enough. I think... |
| run flat tyres | Woodsy20 | Wheels, Tyres & Brakes | 2 | Aug 21st, 2011 09:57 AM |
| Replacing run flat tyres with standard tyres? | Bells | Wheels, Tyres & Brakes | 33 | Oct 5th, 2010 08:46 PM |
| Run Flat tyres | GAX857W | Wheels, Tyres & Brakes | 6 | Oct 6th, 2007 10:56 AM |
| Run Flat Tyres | RYN | Wheels, Tyres & Brakes | 20 | Aug 23rd, 2007 09:07 PM |
| Run flat tyres | GTT 280 | First Generation MINI Cooper | 10 | Feb 12th, 2004 09:07 AM |
