Tyre Pressure Warning Light Runflats - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 6 (permalink) Old Mar 23rd, 2012, 01:24 PM Thread Starter
Local Time: 02:52 AM
Hi
I have a 2002 Mini Cooper and today the tyre pressure warning light came on and stayed on solidly. I stopped at a garage and checked all the pressures and all were at 30 psi except for the driver front which was @ 25 psi. I put air in the front driver side tyre to bring it up to 30 psi and continued my journey. Now the type pressure light is continually flashing not as it was before. Does this mean something different? how does it know there's still a problem if it just works on tyre pressure?
As luck would have it I was booked in to have the driver side front replaced tomorrow due to wear anyway...
bud79 is offline
post #2 of 6 (permalink) Old Mar 23rd, 2012, 01:39 PM
jbz
Local Time: 03:52 AM
South Africa Male
Reset/recalibrate the alarm and see if it comes back again. I was told by the dealer that one may have to do this occasionally. The procedure is in the manual.
Also, I think it will not clear by itself. You have to do it manually.
jbz is offline
post #3 of 6 (permalink) Old Mar 23rd, 2012, 02:40 PM
Macguyvic
Macguyvic's Avatar
Local Time: 08:52 PM
Quoted: 1 Post(s)
United States Male
You have to go in through the menu marked setting. Go to tires and then prompt it to reset the tire pressure monitoring.
Macguyvic is offline
post #4 of 6 (permalink) Old Mar 23rd, 2012, 03:12 PM Thread Starter
Is this correct for MK 1 (2002) instrument panel?
bud79 is offline
post #5 of 6 (permalink) Old Mar 23rd, 2012, 03:30 PM
harvey94's Avatar
Local Time: 01:52 AM
Male
Hi,
Locate the reset button positioned below the handbrake handle.
Turn the ignition to position 2, press and hold the reset button until the yellow indicator on the dash lights up for a few seconds.
The vehicle is now ready to recalibrate the TPS system on your next drive. After a few minutes of driving, the system will calibrate to the newly-installed or adjusted tires and properly set the pressures to be monitored.
Just a side note..... My light did not go out until i switched off engine and restarted car, so do as it says but if light stays on then pull over , switch off car and turn back on, worked for me......
I love my Mini more than my wife
harvey94 is offline
post #6 of 6 (permalink) Old Mar 23rd, 2012, 10:51 PM Thread Starter
Originally Posted by harvey94 View Post
Hi,
Many Thanks for this
bud79 is offline
tyre pressure warning light grame First Generation Faults & Fixes 4 Nov 30th, 2014 12:14 PM
tyre pressure warning light sillyboy General Discussion 4 Jan 30th, 2011 11:29 AM
tyre pressure warning light problems sweetelite73 First Generation Faults & Fixes 2 Aug 9th, 2009 09:15 PM
Tyre Pressure Warning Light - False Alarms Restyle Wheels, Tyres & Brakes 2 Feb 22nd, 2005 01:23 PM
Tyre Pressure warning light. geonot First Generation Faults & Fixes 16 Dec 15th, 2003 08:19 PM
