PSI for non-run flat tires? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Sep 13th, 2012, 11:18 AM
Local Time: 05:51 AM
England PSI for non-run flat tires?
Hi all,
Anyone know what the recommended PSI is for non-run flat tires on my Mini Cooper 2002 Auto is?
Thanks,
TD
Old Sep 13th, 2012, 01:01 PM
Mine runs size 205x45x17 run flats and the pressure for those is 2.6 bar, 37.7psi
Old Sep 13th, 2012, 03:28 PM
Local Time: 04:51 AM
United States Male
Its 35psi I believe.
Old Sep 14th, 2012, 09:22 AM
For non run flats?
Old Sep 16th, 2012, 07:11 AM
harvey94's Avatar
Male
Tyre pressure is not calculated on the actual tyre , its done on the weight of the vehicle.
You will see that the nun has a psi of 37.7 on a tyre 205x45x17 , i have roughly the same tyre except a different side wall height , 205x40x17 and my psi all round is 30 , different car then different psi , just follow what it says in the manual.
I love my Mini more than my wife
Old Sep 16th, 2012, 05:24 PM
On the same size non-runflats, mine says 2.8 bar, 41 psi.
I don't think the advice to look in the manual is much help as both my 2nd Gen cars' manuals haven't given tyre pressures - instead the manual says to look at the door jamb sticker.
Mine says 2.8 bar for 15s and 17s, and 2.6 bar for 16s - a curious mix.
Old Sep 28th, 2012, 03:08 AM
Local Time: 12:51 AM
Quote: Originally Posted by thedynamix (original)
Hi all,
Thanks,
TD
Max air pressure minus 2 pounds, then adjust as you see wear patterns.
Old Sep 28th, 2012, 03:23 AM
bmwr606
Local Time: 11:51 PM
if you have a buddy that does track days, he/she may have a tire pyrometer
pick a pressure and drive the car, them measure the temp of the tires across the tread, you are looking for even temps across the tire
if the center is higher temp, drop the pressure and try again
if the center is lower, raise the pressure and try again
my cms all4 calls for 32 psi all around, i am running 42 frt/36 rear using the above method
at 5k miles i rotated the tires and measured the tread depth, 7/32 left on all 4 tires, all the way across the tread
the pressures you find this way will only apply to the particular brand/model/size of tire, if you change the tire to different brand or model or size you need to start over
scott
2012 CM S All4 (03/12) | Abs Black w/White Roof/Mirrors/18" White Wheels | Cold Pkg | Sport Pkg | Xenon w/ Black Housings| Manual | Sport Susp| Anth Headliner | Flat Load Floor | Bluetooth | 2 Part Center Rail | Milltek downpipe back exhaust
Old Sep 28th, 2012, 05:55 AM
United Kingdom View Ian Kuah's Pure Silver & Black 1st Gen MINI Cooper Profile
Hi all,
Thanks,
TD
The MINI is a front-wheel-drive car with a forward weight bias, therefore the front tyre pressures should be higher to minimise understeer and improve steering feel and turn-in.
If the rear pressures are too high, the car will be skittish under hard braking and when you lift off in a bend, especially in slippery conditions.
I have 16-inch non-runflats set at 30psi front and 24psi rear on my 2001 Cooper, and the car is very neutral and progressive on the limit. It is also perfectly stable at top speed on the German autobahn with these pressures.
I am a professional road tester by the way, and contributor to BMW Car and MINI World magazines.
Old Sep 28th, 2012, 10:03 AM
Ireland
I'm gonna agree with this in general. The UK/Ireland recommended pressures for the R50 are 32/32 psi IIRC
Good for fuel economy, not optimal for enthusiastic driving.
30 and 26,27ish are what I've been using in my wife's R50 (15inch non runflats). That's for 2 front seat occupants and negligible luggage load. We both agree that this makes the car much more stable/predictable in the twisty bumpy stuff. I do bring them back up to 32/32 for extended motorway runs or urban commuting.
Old Sep 28th, 2012, 10:42 AM
Derepente's Avatar
totalMINI punto com
Local Time: 06:51 AM
United States Male
I have non run flats. I use 39psi on all four. If i use anything less, seems like i have to top off the air more frequently. On the door frame you can reference recommended psi levels.
Now I am Looking forward to the commute! MINI Cooper S Cabrio
Old Sep 28th, 2012, 01:41 PM
Macguyvic's Avatar
Macguyvic
United States Male
It's listed on the door jam of your car with pressure listed based on the original equipment tires.
Old Sep 28th, 2012, 04:32 PM
Tyre presure
Hi
I have been running a 2002 mini on non run flat tyres for 6 years now at 2.1bar or 31/32 psi
after comming out the bmw dealer last year they set my tyrs to 37psi and nearly killed me as i went round a corner and almot ended up in the hedge
i run on dunlop sp9000 205/45/17
hope this helps
this info is also on the inside of your filler cap
