BMW Bottlecap Wheels - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Oct 13th, 2012, 03:13 PM
Aly
Local Time: 08:23 AM
Looking for some winter wheels for my Mini
These are 4 x 100,
Wheel size is 6J X 14 ET35
Does anyone know if these will fit?
Old Oct 13th, 2012, 03:19 PM
Caveman's Avatar
Local Time: 10:23 AM
No ... you'll need at least 15" wheels, and it will depend on the size of the brakes on your car.
Old Oct 13th, 2012, 03:28 PM
Aly
Thanks Caveman I only have standard Cooper S brakes so I'm sure they should fit over them?
Also the offset is ET35 and I've found out the Centre bore is 57.1mm.
I found someone who said on here though that anything over 56.1mm will need to be increased as it will vibrate?
Did you say no because it wouldn't clear my brakes or just because it wouldn't fit.
Old Oct 13th, 2012, 05:07 PM
tnoy66's Avatar
POP..POPPOP..POP
Local Time: 09:23 AM
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
1st gen S needs 15" minimum
2nd gen S needs 16" minimum
The ones you mention are only 14" so no chance of them fitting
Old Oct 13th, 2012, 08:01 PM
Caveman's Avatar
If the centerbore is larger than 56.1mm hub-centric rings are needed to prevent wheel shimmy at higher speeds.
