Constant brake squeal (no braking) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Feb 7th, 2013, 02:54 PM
Local Time: 11:59 PM
Hi Everyone:
Two weeks ago I changed out the rear brake pads on my R53 (2005 S) with generic pads. Immediately the rear brakes started squealing while driving, without the brakes applied. I could temporarily stop the squealing by applying the brake or the emergency brake.
About 10 days later, I was convinced that the generic pads were to blame, so I replaced the brake pads with genuine MINI parts. Now the problem is worse and non-stop. I can make the squeal worse by aggressive cornering or hitting a low or high spot in the road. I can still solve the problem temporarily by applying the brake; but only for a few seconds.
Could my rotors need changing (both rears contain a lip on the very outside edge; normal?)? Could my calipers need lubing? Or, is it that the pads need to wear in?
Any help on this would be greatly appreciated!! Thanks!!
Old Feb 7th, 2013, 05:17 PM
Local Time: 07:59 AM
When you fit new pads it always helps bedding them in if you roughen up the disc glazed friction surface with a bit of emery cloth.
There are areas on the back of the pads they tell you to apply a little anti squeal grease too such as copperslip
Old Feb 7th, 2013, 07:32 PM
And...
Thanks for the reply. I will try that.
I should also have mentioned that my fuel efficiency has plummeted by almost 20% since installing the new pads. I notice that when I push the car around in the garage, I can hear BOTH brakes scraping. Will this go away? Will my fuel efficiency come back once the pads are worn in?
Old Feb 16th, 2013, 07:33 PM
sounds like the handbrake adjusters were not slackened off. How much travel on your hand brake now?
Tab
